another 3.4 write up
Old Oct 7, 2008 | 04:41 PM
cartune777's Avatar
crossover is done hope it works i used all the original tubes, like i said im trying to do the whole thing for under 1500 to see if it can be done, here are some pics,
3.0 dipstick
crossover
Old Oct 7, 2008 | 04:49 PM
fillsrunner4's Avatar
Originally Posted by cartune777
Are you gonna be able to get to that top left bolt (near the flex pipe) when the bellhousing is attached??? Looks real close in that pic! Might be tuff to get the tranny in but could just be the picture!
Granted looking at it again with the bolts not on holding up the crossover it should pick up some it looks like away from the tranny!
Keep it up dude!
Old Oct 7, 2008 | 04:59 PM
cartune777's Avatar
yup its the picture and the fact its not bolted up, the bellhousing clears though,
Old Oct 7, 2008 | 05:04 PM
Nice! Just wanted to bring it to your attention if it was gonna be in the way!
Old Oct 17, 2008 | 07:38 PM
  #25
cartune777's Avatar
so i finally got my manual harness in, about to do some wiring, does any of the wiring from the original body harness have to plug into the ecu? if so which ones?
Old Oct 24, 2008 | 12:11 PM
  #26
cartune777's Avatar
just an up date, for the clutch i used the 3.0 clutch, flywheel, pilot bearing, and throwout bearing, with the 3.4 starter. for the oil i used the 3.4 baffle, 3.0 pan, 3.0 sump and 3.0 dipstick, everything bolted together well and the motor and trans is mounted in the truck
Old Nov 4, 2008 | 04:24 PM
  #27
cartune777's Avatar
got the radiator, fan, exhaust, and steering hoses all hooked up, as well as the modified 3.4 alt harness, for the rad. hoses i used the both the 3.0 ones, my truck has abs so i used the 3.0 power steering hoses, all hoses fit perfect
Steven.m.paulk
Jun 7, 2020 10:45 AM
White Stripe
Oct 6, 2015 10:47 AM
Draven023
11
Oct 1, 2015 06:47 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
tshort48
Sep 27, 2015 01:04 PM
