3.4 swap Question
Old Jul 6, 2009 | 05:11 PM
Ahbustae86's Avatar
3.4 swap Question
Can I use the fuse block thats in the engine bay of my 3.0 or do I need the 3.4 one?
Old Jul 6, 2009 | 07:57 PM
RobD's Avatar
Use the 3.0 fuse block. You'll have to move the battery to the driver's side, because the 3.4's intake is on the passenger side. Run a heavy gauge wire from the battery to the fuse block and you're done.
Old Jul 6, 2009 | 10:20 PM
Ahbustae86's Avatar
Thanks RobD. Can I use the 3.0 charcol canister as well?
Old Jul 6, 2009 | 10:32 PM
904_runner's Avatar
Yes you can..
Search around on here.
Many have reused the 3.0L charcol cannister,
I am actually using mine now, but i need to get my 3.4L one replaced so i can go see the referee for smog in california.
Old Jul 7, 2009 | 04:46 AM
yodathespian87's Avatar
Evolta and Brenkrjai have the diagram for the charcoal canister. So I would check those 2 threads out. Very helpful.
Old Jul 8, 2009 | 01:00 AM
Ahbustae86's Avatar
Yoda- Thanks for pointing me in the right direction.
Looking at the drawings, it looks like I'm using the VSV from my 91 4runner. Does the electical connector from the VSV bolt up to the 3.4 ECU harness or do I have to figure out the wiring on that as well.
Old Jul 8, 2009 | 04:58 AM
Yes they do. At least 2 of them do. You will notice they have a little tab off to one side which only allows that exact plug to plug in. As for the wiring check out TIS.com and http://www.ncttora.com/fsm/index.html
Here are a few other wiring threads that might be helpful.
https://www.yotatech.com/forums/f160...e-help-162300/
https://www.yotatech.com/forums/f160...wiring-155380/
Then my thread- still working on mine
https://www.yotatech.com/forums/f160...13/index2.html
Flying91
45
Apr 11, 2024 04:39 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
94whiterunner
Jul 12, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
Cplmike
Jul 8, 2015 08:47 PM
