Which motor and tranny do I need?
Old Apr 27, 2009 | 04:18 AM
Gravehunter's Avatar
Hello,
I have a chance to buy a 1990 toyota pickup. ext cab, automatic, with a 3.0 thats no good. no rust, good shape, nice interior etc... for $600.
I'm heading to work and won't be able to do anymore searching and am looking at the truck after work. From what searching i have done there is conflicting info in difference threads.
Will the 3.4l bolt onto the auto trans or not? Some say no, others say yet but have a error code on all the time etc... Some threads are old though.
Just trying to figure out if i should get the truck if it looks as good in person as it does i the pics.
I've got a regular cab Nissan now and would really like the extra leg room and power of this toyota setup if it will work out.
Thanks for the info in advance.
Last edited by waskillywabbit; Apr 27, 2009 at 05:57 AM. Reason: Title clarity per posted sticky
Old Apr 27, 2009 | 04:46 AM
yodathespian87's Avatar
As far as I know yes they will. R150 (I believe is the trans code) Will match the 3.4. The big issue is to find an engine to match the tranny you have. you just want the ECU's to match. Just my .02
Old Apr 27, 2009 | 04:48 AM
so i would need a 3.4 out of an automatic Tacoma?
Old Apr 27, 2009 | 05:31 AM
jskijoe's Avatar
I believe if you're truck is an auto, you have to get the donor motor from an auto for the computer to get signals from the tranny
Old Apr 27, 2009 | 06:53 AM
ok, i can do research on what engine i need etc.. if i get it.
Just wanted to make sure it was do able so i didn't get stuck with a truck i couldn't do it with.
Thanks for the fast replies guys!!
Old Apr 27, 2009 | 07:05 AM
I don't know where you are at but here in colorado springs /denver, auto 3.4 engine are easy to find its the manual one that are hard to find. Be sure to get the whole package. You want an uncut harness with ECU that matches the engine year (preferably from the same donor vehicle)
Old Apr 27, 2009 | 07:18 AM
904_runner's Avatar
X2!
Get everythign you can get from the donor truck.. Its soo much easier to have everything you need. than have to source parts.
Old Apr 27, 2009 | 09:35 AM
TMZ's Avatar
TMZ
The R150 is a manual trans. Yes the 3.4 will bolt to the existing trans in the truck. Yes it will drive down the road. Yes you may see DTC's and imcorrect shift patterns. The correct way to do this is use the auto trans from a 3.4 and get the adapter for the older style t-case.
Old Apr 27, 2009 | 10:01 AM
Thanks everyone for the quick info.
I went there over my lunch hour and bought it.
Heres the pic he had in his ad. Bad pic.. but only one i got.
It has no rust if you can belive that!!
Time to do some swap info searching... thanks to those who have already posted info about that!! I'll do alot of research and then probably post to make sure i will be buying what i need before i do just to make sure.
I finally got a Toyota!!
Old Apr 27, 2009 | 10:37 AM
Dan.3's Avatar
WOW!!!! lots of bad info in this thread with the expection for one post
Old Apr 27, 2009 | 11:22 AM
Thanks for being helpful! Maybe point out what exactly was wrong and what was right. Here are some links I found useful. May they come in handy for your swap...
https://www.yotatech.com/forums/f160...16/index2.html
https://www.yotatech.com/toyota-research/f-160.html
http://www.pirate4x4.com/forum/showt...5&pagenumber=1
https://www.yotatech.com/forums/f160...85/index2.html
http://www.4x4wire.com/index.php?opt...tech&Itemid=53
https://www.yotatech.com/forums/f160...38/index3.html
https://www.yotatech.com/forums/f160...eknraj-161816/
http://www.4x4wire.com/forums/showfl...=&fpart=1&vc=1
http://www.andrewzook.com/content/view/22/48/1/2/
Old Apr 27, 2009 | 12:08 PM
Well i wasn't really posting for swap info yet. I will search and get the info i can first. Everyone hates a noob that doesn't search first!! But if you know there are some bad info posted please speak up as to what is wrong if you would.
Old Apr 27, 2009 | 12:09 PM
WOW.. thanks for the links!!!! That will get me started!!
I see by your sig that your in the middle of the same swap. hows it going?
I'm going to pick it up tonight!
Old Apr 27, 2009 | 12:10 PM
Well that may be a good option if i come across a good deal on a wrecked truck or somthing
Old Apr 27, 2009 | 12:13 PM
Originally Posted by 904_runner
X2!
Yah i think finding a wrecked one at a yard may be a good option so i can get all of what i need from it. I need to get to researching and see what my options are.
Probably going to need some more money!! LOL
Old Apr 27, 2009 | 12:15 PM
I'm about 9 hours from Denver(Iowa) so thats doable if i needed to.
I've got quite a bit of salvage yards near me, but never done this kind of thing so not sure what thier policys are for the engine(warranty) etc...
But very comfortable fabbing things up, welder, plasma cutter.. etc.. so not worried about any of that if its needed.
The adventure begins!
Old Apr 27, 2009 | 01:07 PM
Well I just picked up the engine on Friday afternoon. Cleaned it off this weekend. Re routed the fuel line, thats about it so far. I will pickup the new clutch and some other stuff the next pay check I get. Mine is a little different then yours, manual trans. And its a 93 4Runner, but very excited to get this started. Cadman, Mt. Goat, FillRunner and Evolta have bunches of info on the swaps.
Old Apr 27, 2009 | 01:19 PM
waskillywabbit's Avatar
Gravehunter,
Good luck with your swap.
Also there is a "multiquote" button on each post if you want to reply to multiple posts.
Multiquote click each one until the last one and then hit quote and it will quote them all so you can do one post for all your responses.
Old Apr 27, 2009 | 06:40 PM
Ah i see, I wish this truck was a stick instead but i guess the price was right so i'll take what i can get! Time to start hitting the links you gave me and read up now.
Originally Posted by waskillywabbit
Gravehunter,
Hey... that would have been way easier wouldn't it! LOL
I'll know for next time.. thanks!
Old Apr 28, 2009 | 04:39 AM
yawn..... lots of hours reading swap info... need more coffee.
So far to keep my stock auto trans i need a 3.4 with injector harness out of a 4x4 tacoma and use a t-100 ECU and wiring harness instead of the tacomas so i don't throw codes.
I'm still researching... but just tossing that out there to see if anyone objects.
