1990 runner and question...
Old Aug 22, 2008 | 11:08 PM
elnino's Avatar
so im planning to do this swap...but..i mud a lot...which also means i go under water a lot..i need the snorkel....how will that work with the 3.4 swap?...
will the other snorkel fit?..whats the deal here?
Old Aug 23, 2008 | 08:47 AM
cadman's Avatar
Any snorkel kit for the 3.4 should work, although you may need to do a little custom fitting since the fenders are not the same as the previous generations.
In my swap I fitted the intake duct from the 3.4 and there is more than enough room: https://www.yotatech.com/forums/f160...16/index5.html
I don't know if snorkel kits for the 3.4 replace the duct or hook up to it, but either way shouldn't be any problem.
Old Sep 2, 2008 | 10:44 PM
freefallmarine's Avatar
White Elephent, did you go through with the snorkel?
Old Sep 3, 2008 | 09:08 AM
RobD's Avatar
The 3.4 has it's intake on the passenger's side, the 3.0 has its on the driver's side. You'd need a snorkel that fits through your passenger side front fender, since the 2nd gen snorkel kits go down the driver's side.
Old Sep 25, 2008 | 09:58 PM
fillsrunner4's Avatar
Its gonna be custom for you and can be done. I bet you could mock up a 3.4 snorkel for it or but its still gonna take custom work! No one make a direct fit snorkel for the swaps!
People do however make there own all the time using pvc and whatnot!
MMA_Alex
25
Apr 18, 2017 05:07 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
ptb12
Jul 5, 2015 01:49 PM
