3.4 swap bogs like crazy
Old Aug 17, 2009 | 12:09 PM
Runnerfan's Avatar
I just got the swap mostly finished, but when I give it some throttle it bogs at first then revs up(this is when parked). When I am driving(under load) if I give it more than a feathering of throttle it will just bog and never come out of it until I let off of the gas. I flipped my MAS incase I had it in backwards and unpluged it and it seemed to be doing the same thing. It had no codes until I unplugged the MAS. I am also running the stock 3.0 exhaust setup with the 2nd O2 sensor installed, would the stock exhaust create to much back pressure, could this be my problem?
Any help would be great thanks.
Old Aug 17, 2009 | 12:14 PM
904_runner's Avatar
Okay lets trouble shoot..
Make sure all the grounds are the motor are completed.. If you are missing some grounds then it will not run properly.
I would check there first, you need all the sensors hooked up as well.
Old Aug 17, 2009 | 01:02 PM
Runnerfan's Avatar
I can't see any disconnected ground, off the top of my head I can think of 3 that are connected. I pulled the motor and trany out of a crashed donor, so I left everything plugged into the motor and pulled the wiring harnes out of the fire wall. I also have 2 more questions. Does the fuel pump run constantly on these or should it cycle when it pressures up? And since I put the new M/T in place of my A/T is there some more sensors I need to get from my donor? And I just cut the engine/body harness for the body harness plug, what all should I need to run back into that?
Old Aug 17, 2009 | 01:38 PM
904_runner's Avatar
Okay so we need a little more info..
WHat vehicle do you have? Year, trans, engine.
What did the donor come from? Year, trans,
Old Aug 17, 2009 | 02:05 PM
vital22re's Avatar
totally a bro
did you check the tune up on the motor?
Old Aug 17, 2009 | 02:20 PM
Runnerfan's Avatar
My 4Runner is a 92 A/T. I swaped out the motor and trans for a 96 4runner with a M/T. I have the donor sitting out back if there are any parts I need.
Old Aug 17, 2009 | 05:19 PM
Runnerfan's Avatar
All know is the spark plugs looked good.
Old Aug 17, 2009 | 05:23 PM
Runnerfan's Avatar
The igniter from my donor was destroyed so I got one on ebay. Are most 6 cyl igniters compatible around this year? I ask because a few of the wires were different colors, but I used my EWD from techinfo.com and the igniter was labeled.
Old Aug 17, 2009 | 08:18 PM
Runnerfan's Avatar
Does it matter what the wattage of the resistor is for the tach mod?
Old Aug 17, 2009 | 09:29 PM
vital22re's Avatar
totally a bro
are they the double ground electrode?-the spark plugs. Original plug wires?
Old Aug 18, 2009 | 09:13 AM
904_runner's Avatar
10k-Ohm.
Bought a pack of 5 from radio shack for $1
Old Aug 18, 2009 | 09:50 AM
Runnerfan's Avatar
I was looking at radio shack's site and they have a few types of 10k ohm resistors that vary by wattage(1/4w,1/8w, 1/2w). So does the wattage not matter, because I can't find any info?
Old Aug 18, 2009 | 09:55 AM
Runnerfan's Avatar
I don't really remember what they were. I was going to compare with my 3.0 plugs because I had just changed them, but the 3.4 plugs looked like they came right out of the box.
Old Aug 18, 2009 | 12:55 PM
Wilko76's Avatar
I don't know what wattage resistor your supposed to use, but I used 1/2 watt (because thats all I could find at the time) and it works ok.
Old Aug 18, 2009 | 02:42 PM
904_runner's Avatar
Same here.
1/2 watt 5% tolerance 10k-ohm resistor.
Old Aug 31, 2009 | 04:21 PM
Runnerfan's Avatar
I think I found the original problem. I didn't have the wire hooked up that powers alot of the sensors. But now I have a different problem. It is hard to start when it is cold, it backfires and has no power, it has more power in low RPM's and revs very slow over 3000 RPM.
Old Aug 31, 2009 | 04:24 PM
Runnerfan's Avatar
Has anyone ever had proplems with pulling codes from the ECU? They kept on getting a error when I tried to get them. I checked and rechecked my plug wires and they are hooked up right.
Old Sep 5, 2009 | 12:53 PM
Runnerfan's Avatar
5 out of 6 plugs.
[IMG][/IMG]
Do they look dry to any one else?
Old Sep 5, 2009 | 12:54 PM
Runnerfan's Avatar
I will try and get a video up of the driving sounds and guages.
Old Oct 27, 2009 | 12:21 PM
agusgus3's Avatar
I have also experienced that issue. I'm going to the shop today again to try and get some codes... My 3.4 isn't even starting right now and the spark plugs are black and soaked...
