quick ecu question
Old Apr 13, 2009 | 01:54 PM
wanna_be_wheelin's Avatar
quick ecu question
i have the 96 3.4 in my truck and the only part i need is the ecu i have a auto harness out of a 4runner but my pickup that im doin the swap on has a m/t what ecu should i get at or mt and what years ecu could i get
Old Apr 13, 2009 | 02:07 PM
904_runner's Avatar
You can supposedly use the auto harness, but you will have to find a manual ecu..
There is a good amount of knowledge that people have done the 3.4 swap using the auto harness/manual ecu, and i have read of people using both the auto harness and ecu on a mt equipped rig.
Right now i am running both the auto ecu and harness, but mine was out of a tacoma. The plugs on mine will supposedly be the same between the auto and manual ecus.
Here is a couple good links..
https://www.yotatech.com/forums/f160...-trans-167739/
http://pirate4x4.com/forum/showthread.php?t=771160
FWIW, i am running an auto ecu/haness with my manual equipped ecu. I have a jumper between the park/neutral saftey switch and am not experienceing any CELS at the moment. After 200+ miles.
Old Apr 13, 2009 | 04:41 PM
TMZ's Avatar
TMZ
The 96 4runner harness has two different style ecu plugs. One for M/T and one for A/T. You will not be able to plug a M/T ecu into the A/T harness.
Old Apr 13, 2009 | 04:53 PM
so my best bet is to get a auto ecu and doing the netruel jumper wire thing?
Old Apr 13, 2009 | 05:15 PM
904_runner's Avatar
I would get the proper ecu..
I don't think mine is running at its full potential cause of this auto ecu.
Old Apr 13, 2009 | 05:22 PM
if i got the m/t ecu i would have to get the m/t wiring harness too as my harness wont plug into the m/t ecu. and thats coin i dont have. so i think i am going to find a a/t ecu and make this sucker run.
jasonty
41
Dec 23, 2018 01:00 PM
RatOmeter
Oct 22, 2015 03:17 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
thefishguy77
Aug 9, 2015 04:15 PM
icentropy
Jul 14, 2015 10:23 AM
