View Full Version : 3.4 Swaps
Pages :
2]
- More 3.4 swap issues
- Exhaust crossover issue in 92 Toyota RV motorhome
- 3.4 swap AC problems please help!!
- Compression Test on Donor Engine (Need some opinions))
- 2WD Oil Pan woes...
- Looking for wiring pins
- Fc wire
- 1998 4Runner 3.4 Engine Replace Question
- Using 3VZE catalytic convertor on 3.4 Swap?
- She's Dead...Where to find a 3.4?
- Tachometer: lost like a ball in high weeds
- 3.4 swap runs for 2 secs then dies
- 3.4 wiring help
- efi resistor
- efi resistor
- 1982 yota
- Want to swap a 5VZ MT ECU for a AT ECU?
- tach issue
- Swap 94 3.0 auto to a 3.4 Manual
- Cs144 or alternative for 3.4
- Swapping T100 3.4L MT into a 92 Pickup AUTO?
- 3.4swap wiring problems
- 03 donor taco startup help
- A340H fluid level on 3.4 swap not accurate after bending dipstick tube
- Idea: Toyota Engine swap site
- T100 MT/AT ECU swap
- 3.4 swap wiring
- 91 3.4 swap no spark
- 3.4 Swap Harness Spreadsheet Review
- 3.4 swap with abs delete. What hose to use?
- 94 4runner 3.4 swap questions
- Powering up the ECU
- 3.4/1994/g144
- 1991 EWD Missing Pages (help)
- 93 cab 3.4 swap ifs vacuum lines
- Technical Info, TIS vin not found
- 3.0 to 3.4 body harness question
- 98 Tacoma 3.4 to 95 PU 3.0 Swap -Tach
- No Start-NOT THE STARTER OR BATTERY!!
- 3.4 swap into 1990 4runner HELP
- 1uz swap
- 3.4 swap with high mileage
- 3.4 Swap In My '95 4Runner
- lower rad hose -NO cut
- Manual transmission connections?
- failed the CA BAR
- Should i go with a JDM or not
- 3.4 clutch and bell house questions. Identifying.
- 99 4runner motor, harness, ecu questions
- olipabs 3.0 to 3.4 JDM swap
- 2003 3.4 VZ swap cooling system
- Question re: 3.4 swap, JDM, and Califoring rules
- T100 Auto Ecu with 2000 4runner Auto Sensor Issues
- 3.4 swap wierd problem
- 3.4 Swap Idle issue - P0171 lean condition...
- Buying an Auction Vehicle
- What's It Like After The Swap?
- 96-97 m/t 4Runner ecm
- 3.4 swap with sas or buy one with a 3.4 and sas
- Rpm Verify
- 3.4l intake/emissions differences from '97 to '01
- Pittsburgh area 3.4 swap help needed.
- Is this right?
- 3.4 swap not running
- To 3.4 swap or to not?
- Alternator wires
- Is vacuum line to AIC normally louder
- 3.4 AT donor - MT recipient (Question)
- PS line sensor?
- Machine the head or new engine?
- 3.4 swap into a 95 4runner - Question
- Bypass ADD electrics and working 4wd light
- 3.4 swap starts then dies
- evap wiring help
- Tanny problems after swap
- Rear heater hoses...gotta be a better way
- 3.4 short block to long block
- 3.4 swap, same trans issues?
- 3.4 swap with auto trans wiring help needed!
- Exhaust question
- 3.4 swap won't turn over...
- Opinions on the 3.4 Swap
- 95 t100 3.4 auto 2wd motor into 95 4runner 3.0 wiring help needed
- New Swap - harness questions
- 99 auto 4runner into 89 manual 4runner
- alternator upgrade issues.
- 3.4 swap custom harness
- 3.0 to 3.4 California smog
- Manual tranny wiring
- 3.4 oil cooler bypass
- Dowel Pins
- 3.0 3.4 conversion
- Jdm vs. US differences
- p0100 and p0141 codes
- Flywheel Bolts
- engine rebuild, need help finding pistons
- 3.4 swap help.
- Failed smog ref due to crossover pipe on drivers side
- 3.4 into 86 4runner
- 1989 pickup 3.4 swap
- 3.4 into 2nd gen 4 runner Have a donor.
- 3.o evap used for 3.4?
- Wiring in OBDII port- ECU connection?
- Oil Sender Confirm
- clutch/flywheel Q...
- 2nd gen 3.4l swap... Have a wiring question
- Wolfrunner 3.4L Swap
- 3.0 to 3.4L swap parts needed
- ECU help!
- 94 4Runner 3.0 to 96 Tacoma 3.4 wiring help!!
- 3.4L Swap and me being an idiot
- evap elimination?
- 1992 4Runner 3.4 Swap Running Thread
- My 89 4runner Project
- Tach mod with pics help
- 22re to 3.4 swap questions
- My new 1990 4runner with a supercharged 3.4
- Dipstick Relocation Issues
- what do I have going on?
- Automatic trans problems. T4r to t100 ecu
- 3.4 lower bell housing cover?.
- 3.4 high idle
- Reverse-engineering a 3.4 into 91 pickup swap: CEL
- 97 4Runner swap into 89 1st gen 4runner
- manual trans issue after swap
- 5vz-fe missing parts
- t100 3.4 engine to Tacoma 3.4 swap issue
- Tyco Electronics ECU Connector Part Numbers
- 1987 22RE swap to 1997 3.4 manual
- Need some help
- 22re wiring
- Wire colors
- Rebuild or JDM?
- no injector pulse
- 3.4 swap homework. Tips anyone?
- Adding Late Model Cruise Control
- 89 4runner 3.4 swap
- How Critical is the VSS line?
- ODB-II to ECU Wiring Help
- 89 Pickup In need of wiring diagram
- 3.4 swap wiring problem.
- Fedral Emissions 3.4 Swap Truck moving into California
- 2 ecu's in one swap...
- Need info to do a 3.4L swap in a 91 pickup 3.0L
- ClintonP929's 3.4 Swap (89 Pickup)
- Slipping clutch with swap
- Looking for a good mechanic/shop near West Virginia (3.4 swap)
- Another 3.4 high idle thread
- R150F to A340F in a '99 tacoma
- Federal and Cali ECU Identification
- JDM Oil Pan?
- 89 4runner 3.4 swap w/r150f trans
- 3.4 swap tranny issues
- Another EVAP plumbing thread
- Is there a 3.4 A/T 4x4 with a right hand drop T-Case?
- 1992 Pickup 5VZ-FE Swap Done! Lingering questions for the experts
- 96 3.4, very high idle no vacuum leaks I can find
- Oklahoma
- A/C doesnt line up
- Reputable JDM engine seller
- Wiring help
- 3.4l enuff hp for d60 and 40"s?
- new tranny harness to an older tranny
- Scan Gauge II -auto temp ?
- Help me Finish My Swap!
- Looking for some encouragement...
- 98 T4R JDM Swap
- In a world of hurt!
- AC pulley lineup with 93 3.0 compressor, 3.4 out of 95 T100
- Three wire to two wire VSS
- Should I buy this motor??
- Techstream Communication after swap
- No More "ECT/PWR" After Swap :-(
- A340H 4LOW Wiring and Sol. #4
- Swap oil dipstick reading
- Runs and Drives but Hesitates and bad gas milage
- E6 Connector from a 2001 Tacoma
- 3.4 swap vsv/misc questions
- Homeless vaccuum line port + small random wire
- no spark searched and searched
- How to Swap Video-Parts needed. Tips and tricks
- 93 SR5 3.0->3.4 swap, speedo works cruise doesn't
- What to look for a swap
- 95.5 Manual ECU (taco) work with a 97 AUTO ENGINE (T100)
- t100 auto ecu years?
- Swap with tight throttle cable
- I'm lost running my fuel line
- 5vzfe swap stalling issues
- 3.4 engine swap need advise
- What's the deal with my A/C pulley alignment?
- Whitey's 3.4 hour tour
- replacingjust harmonic balancer
- Another Adopted 3.4 Orphan Rehabilitation
- 3gen FSM with EWD zip download page FREE
- 3.4 Cold Idle Specs?
- ECU Function sheet?
- 3.4 EVAP VSV Confusion
- 1989 4runner 3.0 auto to 3.4 auto
- ORS crossover issue
- HELP 3.4 swap readiness monitors won't check in.
- 3.0 to 3.4 Manual to Auto
- 1989 single cab engine swap time!
- 3.4 Swap, Starts then dies
- Using 3.0 Fuse Box bracket mount for swap
- 3.4 into an /86 22re
- Oil Capacity Question
- How much for a rebuilt 3.4?
- FC wire does not prime???
- 88 4runner 3.0 to 3.4 out of 1999 runner
- 1989 Pickup 3VZ to 5VZ from 1998 4Runner 4x4 Manual Trans 89661-3D362 ECU
- 3.0 to 3.4 swap problem
- 3.4 5vz-fe Help Please
- 1990 4runner with a 3.4 swap alt problems
- Need some expert confirmation for 3.4L swap.
- My 98' 3.4 swap maybe she will sc in my 85 linked truggy
- 89 4runner 3.4/5speed
- looking for plug end part#'s
- 22re to 3.4 .......use same mounts??
- Installed Flywheel with Flex Plate Spacers
- 3.4 swap into 90 4runner
- Short in EFI fuse circuit when temps went to freezing
- Dave's 92 Toyota Pickup 3.4 Swap
- AW4 to a 3.4?
- speedometer question on 1999 3.4 swap
- 88 V6 xtracab to 2000 3.4 5speed
- 3.4 driveline questions
- ID numbers on motor
- automatic transmission
- BAR ref in Orange County
- AC Hack Job Rant !!
- 3.4/A340F swap - shifter console/surround what to use?
- Adding Cruise Control??
- 96 to 95 down to a handful (hoses/wires/...)
- Just a rant.......
- TG Motor Mount Opinions and Fitment Tips
- Adaptor harness
- Transmission Question
- Body Lift for 3.4 swap on 1988 4Runner
- 3.4swap
- 98 3.4 swappin into 91 3.0 4runner need help!
- 3.4 swap!!
- remote slave to fit stock crossover in passenger drop position
- Ca. ECU Regulations
- How is your cruise control set up?
- finn's 88 pickup 3.4 swap
- Identify the year of the engine...
- Stumped on trouble codes p0135 and p0141
- Finished swap and then rolled it
- Wiring -- I'm doing something wrong?
