Tanny problems after swap
Old Jun 12, 2016 | 03:48 AM
mswierse's Avatar
Tranny problems after swap
Hi Guys! I just completed my swap the other day and started the motor for the first time. I have a 95 4Runner with and engine/ecu out of a 2000. I changed over to a manual tranny (ECU is manual tranny also). My problem is that I can't get the manual tranny to shift into all the gears. It only shifts into what I think is second gear. It feels like it's locked out of all the other gears. I can get it into neutral. So I'm wondering if there is anything I should try before buying another used tranny. Any idea? Thanks in advance for the help!
Old Jun 13, 2016 | 01:53 PM
SacRunner's Avatar
Dumb question, did you install a body lift at the same time? I ask in an attempt to see if the shifter is hitting the floorboard and preventing the shift handle from going into gear.
Also, what transmission did you use? You should be using a 87-95 R150F that was used with the 3.0; others might work, but will need additional work.
Old Jun 16, 2016 | 07:37 AM
mswierse's Avatar
I did put a body lift on... plus I don't have the bezel on, so I can tell it's not hitting the floor. it is an r150f. Bolted right up, clutch is working good.
Old Jun 16, 2016 | 11:44 AM
sphealy's Avatar
Which throwout bearing did you use? The 3.4 or 3.0? Yiu should have used the 3.0 becuase its shorter.
Old Jun 16, 2016 | 06:11 PM
mswierse's Avatar
I have the correct throw out bearing. The clutch works fine. It only goes into one gear. It's a tranny issue, just wondering if there are any common issues that would cause this inside the tranny. The place I got it is trying to get me another one. Think I might go that route.
dbbowen
Apr 15, 2016 11:08 AM
tomanator
Feb 21, 2016 02:22 AM
Calioutdoor
Feb 17, 2016 08:56 AM
captainslow
Feb 8, 2016 09:11 PM
C2damuthafuqinLO
Aug 25, 2002 01:45 AM
