3.0 to 3.4 swap problem
Old Jan 8, 2015 | 09:45 AM
Streetrod19772000's Avatar
I completed the swap and I have no spark and no injector pulse. This ECM came out of donor vehicle which is a 1999 4Runner Limited with transponder key. I have been assured that if you eliminate the ground that this ECM will work. I changed ignitor and still no spark or injector pulse. I have 12volts to Ignitor and injector. I have now ordered an ECM for a non-transponder key 1999 4runner. Is there anything else I could be missing. Scanner communicates with all components. Crank sensor, RPM, Cam sensor, fuel pump. it is all working but no spark or pulse.
Old Jan 9, 2015 | 12:26 PM
vital22re's Avatar
totally a bro
imobilizer most likely at fault
Old Jan 12, 2015 | 11:02 AM
Received my new used ECM and it fired on the first crank. Runs as smooth as glass. 4 wheel drive all shifts and works perfect!!! I couldn't be happier.
Old Jan 12, 2015 | 11:03 AM
millball's Avatar
I love a happy ending.
Charecter1
Nov 6, 2023 10:08 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
coryc85
Sep 9, 2015 06:24 AM
