Looking for wiring pins
Old Apr 30, 2017 | 08:48 AM
128keaton's Avatar
Hey guys, I figured I'd come here for the more knowledgeable about wiring harnesses. Anyway, my knock sensor connector on my harness rotted apart, so I ordered a new one, minus the pins which the dealer wanted $20 apiece for. Ouch. Anyway, I was shown what I needed to order, which was a pin/connector that would sit inside the connector and catch on the plastic. On the back, it had a wire coming out with a brown grommet/gasket.
I've punched what I know into google and have come up relatively short.
Anyone know what I'm talking about?
Old Jun 16, 2017 | 05:43 AM
irab88's Avatar
I know exactly what you're talking about, but bot the specific part number. Toyota uses a standard plug design, so looking at what the plug manufacturer uses (usually a .pdf of part numbers) would help.
I'll try to find something here in a bit.
Old Jun 16, 2017 | 05:48 AM
irab88's Avatar
http://www.ttora.com/forum/8-interio...e-harness.html
https://www.summitracing.com/search/...ls/make/toyota
https://www.ih8mud.com/tech/WireHarnessRepairParts.php
You also might be able to find a pigtail at a junkyard for cheap, or look to theBay for parts.
