speedometer question on 1999 3.4 swap
Old Oct 18, 2014 | 07:25 PM
Streetrod19772000's Avatar
I am swapping in a 1999 3.4 plus auto trans plus transfer case. I know they use an electronic signal for the speedo in the 99 but my 88 is mechanical. There is a hole in the transfer case with a bolted in plug and when I remove it I see the gear to drive a mechanical speedo. Where do I find the part to slip in the hole to run my mechanical speedometer. Any help would be greatly appreciated.
Old Oct 18, 2014 | 10:43 PM
DeathCougar's Avatar
IIRC 88-91 V6 Manual transmission has the correct diameter sensor? As for whether it's the right ratio, can't say for sure.
Take the plug out and go to a local wrecking yard, start pulling speedo drive gears out of trucks/4Runners until you get one that matches up
Old Oct 19, 2014 | 04:32 AM
thank you sir!!
Thank you
Old Oct 21, 2014 | 08:49 AM
anthony1's Avatar
I have a 5spd Trans with speedometer cable. The ECU gets the speed signal from the speedometer. I'm not sure what pin it is...check your wiring.
Old Oct 21, 2014 | 09:22 AM
yeah I know it gets signal from speedo but I have to get the cable working to get the speedo whirling to get the signal. Thanks though man!
Old Oct 21, 2014 | 11:11 PM
vital22re's Avatar
totally a bro
some landcruisers ran a speed sensor that had an electrical out and mechanical out. Not sure if it will bolt on or not. Your best bet is gonna be a mechanical from 88-91 V6 as Deathcougar pointed out.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
TammyMarie
Jul 15, 2015 11:14 AM
94whiterunner
Jul 12, 2015 07:15 PM
cyclist231
Jul 7, 2015 12:56 PM
wilbertd
Jul 6, 2015 07:39 AM
