Dowel Pins
Old Mar 29, 2016 | 01:11 PM
bklf7's Avatar
Dowel Pins
So getting all my clutch parts together and got the flywheel installed. Just realized the new flywheel does not have the dowel pins for the clutch to mount to. Are they a necessary part to have on there or can I run it without them?
Old Mar 29, 2016 | 03:51 PM
bklf7's Avatar
Ok did some research and decided to go with them. Does anybody have the dimensions for them?
Old Mar 29, 2016 | 04:03 PM
wyoming9's Avatar
Red face
Who did you buy the flywheel from is it even the correct one??
Did you check clutch fit before installing the fly wheel it is a real pain trying to install a clutch plate that does not line up.
Why were the Dowel pins not in??
Old Mar 29, 2016 | 04:21 PM
bklf7's Avatar
I bought the whole kit including flywheel off of cl. The flywheel didn't come with the pins and I'm converting the motor over to manual so I never had the pins. I think I may have found the dimensions which is L=18 and od=8 and I assume that's in mm. Can anybody confirm?
SBeckner80
May 24, 2016 05:12 PM
bklf7
3.4 Swaps
35
May 3, 2016 03:52 AM
radiomike
Mar 28, 2016 03:54 PM
bucketofsoupyum
Mar 27, 2016 05:23 AM
