22re wiring
Old Nov 21, 2015 | 06:39 PM
bklf7's Avatar
22re wiring
As I thought I'm having a hard time figuring what wire does what. Can I assume there is a different color wire for each function and no repeating colors as far as it doing another function? So I can check the connectors at say the oil pressure gauge and see what color wire is there and go back into the cab and find that wire color so I know which wire it is?
Old Nov 22, 2015 | 01:52 AM
wyoming9's Avatar
Red face
Maybe Do you feel lucky ??
Toyota can do interesting things with wire harnesses .
What starts out one color could come to a connector and change colors
The only real easy way I have found to do a swap is have both The Engine year and model and the vehicle year and model Toyota Electrical Wiring Diagrams.
I like having the hard copies . In fact I would not even attempt doing so with out them.
Old Nov 22, 2015 | 02:01 AM
bklf7's Avatar
Ok I've got them but thought it might be easier to just follow the wires that are on the truck
Old Nov 22, 2015 | 07:51 AM
Terrys87's Avatar
95% of the wires are the same from year to year but I have seen in about each harness that there is some variance. If your truck is the same year they did carb and EFI, even the same year they changed something. I would want the exact year if it were me.
Another possibility that you could do that might help verify you are on the same wire, is to run a continuity check from one end of the wire to the other. Toyota uses several wires that look similar for example a yellow wire with a purple stripe that could be a burgundy color. Really check the colors and some may or may not have hash marks on the wiring the could make you think you are on the same wire.
For a quick example, look at your wiper motor. They are 4 blue wires but have different stripes and can get confusing.
Old Nov 22, 2015 | 10:45 AM
bklf7's Avatar
Ok thanks a lot. I will see what I can do to screw this up lol
SoCal_Todd
Oct 29, 2015 05:52 PM
FRANCOARMANI
Oct 19, 2015 07:33 AM
spriggan
Oct 10, 2015 10:32 AM
FRANCOARMANI
Oct 9, 2015 01:27 PM
travisamorgan
Sep 2, 2015 01:00 PM
