Dipstick Relocation Issues
Old Jan 5, 2016 | 06:21 PM
IndoorCat's Avatar
Hello Yotatech!
Thanks for all the awesome 3.4 swap information. I tried to search for this and haven't had any luck, so please be gentle
My 3.4 block has the plug installed in the location I want to relocate my dipstick to, and I am having issues driving it out. to the best of my knowledge this is the way I should go about it? I spun it with vise grips in an attempt to break it free and then drive it up and out. I generally would never do this, but hopefully the plug will be disposable when it comes out from the underside. It spun but still wouldn't budge.
What am I missing here?
Thanks in advance!
Old Jan 5, 2016 | 08:06 PM
IndoorCat's Avatar
ahhh, a new low. Replying to my own thread.
Any reason why I shouldn't use heat? As long as I don't go overboard I'm guessing a little input from the propane torch won't get the block much hotter than it would under normal operating temperatures?
Cheers
Old Jan 6, 2016 | 10:07 AM
SacRunner's Avatar
I used a 1/4" socket extension from underneath, I removed the oil pan then drove it out from the bottom.
Old Jan 7, 2016 | 09:06 AM
IndoorCat's Avatar
Thanks, SacRunner!
Other than using a metal punch instead of a 1/4" extension(which I then tried) this was the approach I was taking. After a number of bench punches I decided to drill through the center of the plug in an attempt to weaken it. Then I realized I could just drill a 3/8 hole from the underside and it would function the same as what I was trying to replace it with aside from the imperial hole being slightly smaller.
Hole drilled
Baffle and pick up installed
3.0 oil pan sealed and torqued
On to the next Problem! thanks again for the reply.
Duncan
potatohead
3.4 Swaps
16
Sep 11, 2016 12:07 PM
9322rerunner
Dec 1, 2015 12:43 PM
Elshaunero
Engine Swaps
Nov 30, 2015 11:28 AM
towotaguy
3.4 Swaps
9
Nov 9, 2015 06:40 AM
PT3
3.4 Swaps
Oct 13, 2015 09:39 AM
