3.4 into an /86 22re
Old Jan 15, 2015 | 05:48 PM
slacker's Avatar
doing a swap , in the vendors section ... so I cant post here .
wondering if anyone has the pin outs/wire locals for the /86 22re ?
Old Jan 20, 2015 | 05:14 PM
slacker's Avatar
no one ?
well .. ok ... so I will have the info on my build (in the vendors section) when I get to the wiring part
Old Jan 20, 2015 | 07:21 PM
vital22re's Avatar
totally a bro
Sorry. I don't really have notes. I can send you fsm pictures.
Old Jan 20, 2015 | 08:12 PM
BigBluePile's Avatar
If only you knew someone with an '86 FSM..........
Old Jan 21, 2015 | 05:35 PM
slacker's Avatar
I have the FSM , I was just asking to save me some time figuring it had been done before ...
I will post up my info in my build
Old Jan 21, 2015 | 10:36 PM
vital22re's Avatar
totally a bro
I wired up BBP's 86 1st gen when we 3.4 swapped it.
Old Jan 22, 2015 | 08:30 AM
Truth.
Old Jan 22, 2015 | 04:38 PM
slacker's Avatar
then your the guy I'm going to ask if I need any help !
Old Jan 24, 2015 | 03:18 PM
slacker's Avatar
do you remember the part #'s for the main harness plugs in the passenger kick panel ?
Old Feb 3, 2015 | 04:38 PM
slacker's Avatar
searching for part #'s
Old Feb 3, 2015 | 08:50 PM
vital22re's Avatar
totally a bro
I don't recall any part numbers. I just traced out the wires on the engine harness for reverse, 4wd, a/c compressor. Then measured out my 12v all times, 12v switched, 4wd light, CEL, and just ran a fresh ground from body. I'll see if I can dig up my notes somewhere though.
Old Feb 4, 2015 | 05:32 PM
slacker's Avatar
these are part of the engine harness . they plug into the body harness ... I suppose if I cant find the part #'s for the female plugs , I could use other plugs ..
for example .. the violet wire on the left pictured , I know this is for the "check engine" light
Old Feb 5, 2015 | 05:12 PM
slacker's Avatar
finally , after 50 hours of searching , I found the book I have been looking for ...
all the part #'s for denso harness ends from the early 80's to the mid 90's
wow .. I cant wait to get it
I don't know what is available and what is not ... yet !
coleypull15
Nov 3, 2015 07:41 AM
Tacoma1313
Aug 17, 2015 05:44 PM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
93toyoguy
Aug 2, 2015 07:41 PM
94whiterunner
Jul 12, 2015 07:15 PM
