View Full Version : 3.4 Swaps
Pages :
5]
- Power steering lines?
- Please help demystify wiring for me.
- 3.4 swap wont idle up when cold
- Manual 3.4 Swap, last 25% questions.
- A/C system: Want to make sure I didn't mess up
- Starting my very own 3.4 swap
- 3.4 swap while keeping the a340h
- MAF/Igniter compatibility
- Another "won't start". MREL and IGSW pins on '99 ECU?
- 2nd Gen 5vz swap 4cyl 2.2 to 3.4 v6
- Toyonly wiring harness, still no combustion..
- Need 1997 4runner Cat and back O2 sensor distance for ref visit!
- 3.0 to 3.4 swap wiring help!
- 3.4 Swap: What parts to keep from my 3.0
- AC pulley removal
- Which oil pan to use in your 3.4L swap
- 89 4runner swap
- What oil pan to use on my 3.4
- stock 3.4 Tacoma intake...
- Can this part be removed from the Tacoma's tcase?
- COR not kicking fuel pump on FC isn't grounding
- Anthony's 3.4 swap
- 3.0 header on 3.4
- EVAP VSV: Number of nipples
- Toyota Motorhome 3.0 Swap
- Reusing the 3.4 oil baffle plate
- Stiffener plate 3.0 - 3.4
- removing old AC system
- Time for a regear suggestions please
- Final issue on 5-speed/3.4 swap
- losing steam but almost done...help!
- Intake plenum hoses: Where do these GO?
- 3.4 swap and regear ?
- Why can't the 3.4 motor mounts be used?
- Dipstick relocation on a 3.4 swap.
- Engine code P0450
- AC Wiring
- Junk Yard 3.4 motor, used engine questions
- Differences in Tacoma ECM
- Oil Pressure Sender Unit
- 3.0 to 3.4 engine swap in California
- aussie 3.4 swap
- Last step of 3.4 Swap, Need help PLEASE! ADD SW /4WD wiring
- auto trans wiring help
- 3.4 from a 95 t100??
- a343h 4runner box
- 3.4 swap with SC and no lift?
- 3.4 Swap into 1992 with 340f auto
- 3.4 Tach Issues
- Ecm
- hood scoop??
- OBD II Connector
- 3.4 swap started and ran the first time!!
- Off Road Solution is back in business!!!!
- Manual ECM PLUGS
- PLEASE READ!! Time is short!! 3.4 swap into '94 4runner
- 97 MT 3.4 into 95 Auto/Converted to Manual Wiring Help Needed
- 3.4 swap hose funkiness
- 99 4runner security system swap issues
- ca smog/cat issues are the coolest
- Upper Intake plenum identificaion
- Fuel line too short
- obx header clearance....?
- 98 3.4 into 84 22R
- Coming to the end of my swap, few questions.
- Few questions, yes i searched.
- Tach Mod?
- Igniter Pinout
- Plastic thing on steering shaft
- AC wiring for idle up
- Its Running But now what ?
- help ID'ing the last 3 plugs..
- Gathering info for the 22r - 5Vzfe
- Single O2 sensor?
- heater hose question
- Post up your 3.4 swap cooling system
- 3.4 swap harness
- 3.4 to 340H wiring
- 3.4 swap maf issues
- 22re to 3.4 swap minus smog stuff
- o2 sensor troubles
- DANGER No Coolent Flow after swap!
- I'm trying the 3.4 swap!
- Fuel Return hose question
- Is my ECU fried? Any way to test it?
- Wife crashed the 4Runner last night.
- 94 4runner 3.0 to 96 Tacoma 3.4 Reverse Issues
- P0125, New O2 sensor. Location questions?
- Finally a Donor
- Questions for 98+ swaps
- Dual case crossmember? What did you use?
- Power steering hose
- 3 wire to 4 wire TPS swap
- Whaddaya do with the carcass of your 3.0L
- 91 SR5 3.0 Conversion To 98 T100 3.4 Wiring
- Does anyone know what IH1 pin 12 is for?
- Who is running a 96 manual ECM with a 3wire TPS
- anyone have TIS access right now??
- custom xover fit issues
- 1994 4runner IH1 & IH2 Wires
- Quick question about plugs for ECU
- merging wire harnesses
- CGuava's 3.4 Budget Buggy Swap
- 3.4 mix and match questions
- Couple issues have arisen
- a340h S4 pin question
- A/C for 3.4
- 95 t100 3.4 into 89 truck help
- Back to the drawing board 2002 3.4 auto into 91 manual
- Starts, Runs then Dies
- Can Oil Pan Baffle from 3.0 be used on 3.4?
- what to do with my little old 3.slo
- CA smog O2 sensors
- 89 4runner w/ 96 3.4l auto ecu supercharged
- A couple of questions for the pro’s (Auto Trans)
- 3.4 wont start when cold
- support bracket for modified crosssover.....who is running one?
- I need the 96 3.4 EWD
- 98 4Runner motor in 97 T100?
- rebuilt 3.4 burns 1-2 L/week
- 3.4L swap trans, ECU, and wiring questions
- 3.4/trans/dash swap into 85 using 3.4 trans???
- Cold Start Injector wire
- differnce between r150f's
- no spark?!
- 3.4 swap ecm bad?
- dumb muffler/ref question
- i have a few questions ab my 3.4 swap... pls
- A few 3.4 swap questions for the pros out there.
- Advice needed on swapping 96 2.4 with a 3.4
- crossover vs capping manifold
- smithy's 1991 4runner 3.4 swap
- 3.4 wiring help needed
- Looking for a 1979-1983 swap
- Suggestions Procedure for Tracing Wires
- automatic 3.4 engine with manual 3.0 transmission
- speedo question
- EWD's for an 89 pickup 22re
- Compatibility '98 Tacoma Donor to '93 4Runner
- need swap mechanic referral
- Will this damage anything?
- Throwout bearing usage?
- 3.4 Starting problem (wiring related)
- Trottle cable ?
- HELP! 3.4l swap no work.
- NEWBIE's CHEAP SWAP 3.4 from 97 4runner auto ----> 88 4runner 3.0 5speed
- Fuel Pump Wiring?
- 99 Taco VSS Question
- Can't find a 5sp doner truck. Auto OK?
- Catalytic converter question
- dipstick moved to new location and now loose...
- 3.4 Swap Timing/bogging problem
- do i need the evap vsv?
- 2001 4runner EWD's
- Engine Wiring harness housing question.
- 3.4 swap with auto question???
- AM2 30A fuse has started to blow
- oil dipstick location...
- Megasquirt on a 3.4 conversion?
- oil cooler
- 90 4runner with 99 3.4 and gen 1 SC?
- A few more wiring questions...just to clarify
- 89 22re to 98 5vzfe by deyzin
- hoses
- 3.4 drive by wire
- 3VZE to 3.4 swap wiring problems
- Engine revving out of control
- wiring help
- HARRENSTEIN's 3.4 swap into '93 4runner
- Is The Price Right???
- You guys using the ToyotaSwapsOnly crossover....
- 3.4 into my rocky Daihatsu
- after conversion- clutch noise, help!
- head gasket HELP!?!?
- Tieing a 95 Electric speed sensor into a 96 Taco cable ecu?
- 3.4 Swap Wiring Theory (by theMonch)
- 3.4 Rebuild. Have some hypothetical questions
- 3.4 swap shop needed in phoenix, AZ
- Who Sells Conversion Wiring Harnesses?
- If someone would supply me with a full electrical diagram for a '97 T100
- Inspection in NJ as of 8-2010
- Question about Powersteering line
- 2001 Tacoma 3.4 into 93 4Runner- won't start!
- Which headers for the 3.4 swap?
- 3.4 powersteering line? ??
- silly wiring and obd II confusionssss?!?!
- 3.4 swap almost done but won't stay running!
- Speed sensor or cable
- Can't find connector
- Dream Machine: 89 4Runner 22RE to 5VZ-FE w/ S/C
- MaK92-4RnR's 3.4 Swap
- 90 4Runner T100 3.4 swap questions
- 3.4 swap runs! but only for 5 seconds then dies :(
- Fp+ wire. Where does this hook up?
- What would you pay for a 3.4L?
- Quick Draw's 3.4 Swap for Doris
- Yota army guys 1990 4runner 3.4l swap
- 808-5vz swap...
- Vacuum Disconnect Differential after swap
- NEED Motor to Trans Mounting Help!!
- Engine to Tranny bolts? Which to use?
- Oil Pan Question
- 3rz-5vz swap
- wiring help please.
- Stock Reverse Lights- Trans- Wiring help
- 3.4L swap on a automatic 4wd 2ndgen 4Runner possible?
- 95 fusebox okay to use in swap?
- diffrent 3.4 supercharger
- shroud doesn't fit
- Oil pressure concerns with 92 & earlier SR5 clusters....clarified
- anyone still making 3.4 swap wiring harnesses?
- 3.0L or 3.4L Slave Cylinder?
- 97 4Runner 3.4l ecu and harness questions
- A/C Compressor Bracket
- Some cooling info with the 1st gen cluster....need confirmation
- Does anyone have wiring diagrams for a 1989 Pickup?
- Lower Rad house and heater hoses
- Vac hoses stumped...
- Lookin for an experienced swapper in OR (503)
- Trany speed sensor problem
- 5VZ Supercharger Bypass Valve Adjustment
- 88 pickup 5vzfe swap
- oil pressure with a loud tick
- Any downsides to using a 2002 3.4 for a swap?
- 2003 3.4 swap elec TB problem
- Motor Mount issue
- Why do I keep blowing my EFI fuse?
- EVAP box
- Simpl Body Lift for 3.4L Swap Question
- What are you using for your O2 sensor bung?
- Oil Filter relocation questions - I did lots of searches first!
- snorkel on a swapped truck? anybody
- Transmission Question
- Engine/Transmission stiffener plate - Is it necessary?
- Trans problems again. Help and ideas needed.
- southern utah wiring help
- '93 PU with '00 5vzfe, ECU problems
- 93 4runner auto looking 3.4 info
- Speedometer wiring help please and thank you.
- 3.4L Swap guide... in Spanish?
- Anyone near Arkansas - help
- Dipstick tube bracket relocation pics - please add yours
- After this swap sitting for almost a year Im ready to finish it with some help...?
- Need help with EVAP parts
- tach mod...22re to 5vz
- ORS 3.4 Drill Guide
- 3.4 swap - 99 taco into 90 4runner
- 2002 Tacoma CCV/VSV wiring
- overheating?
- ADD solenoids needed for swap?
