Trany speed sensor problem
Old Aug 25, 2010 | 01:13 PM
mrbags's Avatar
i did a 3.4 swap in a 86 runner. and i put the 4cly tcases behind the auto. so now im missing the speed sensor that feeds the speeed meter and comp info. so theres a check engine light on. does anyone have a way around this.?
Old Aug 25, 2010 | 08:50 PM
dntsdad's Avatar
marlin sells them to go in the gear driven case. Get ready to bend over for one.
call them up and tell them what you have and they will line you out.
Old Aug 26, 2010 | 06:09 AM
mrbags's Avatar
but i need to keep the gear driven speedo.
Old Aug 26, 2010 | 06:45 PM
dntsdad's Avatar
call Marlin and tell them your needs and what you have.
Old Sep 3, 2010 | 05:42 AM
dntsdad's Avatar
http://www.marlincrawler.com/transfe...eed-sensor-mci
Check this out. Give Marlin a call and see if this is what you need. Looks promising and cheap.
Old Sep 3, 2010 | 08:16 PM
thefatkid's Avatar
You forgot to wire the speed sensor that is in the instrument cluster head. That will take place of the VSS. If your missing the output shaft speed sensor your SOL.
If you look in the EWD you will see that the 86's speed sensor was never in the transmission.
sandyota
Feb 4, 2021 11:16 AM
XtraCab
Apr 12, 2020 05:25 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
wilbertd
Jul 6, 2015 07:39 AM
karbin
Jul 5, 2015 11:37 PM
