Toyonly wiring harness, still no combustion..
Old Jul 13, 2011 | 04:40 PM
tacovr6's Avatar
I am just about ready to give up on this 'project' as of tonight. I had a harness buily by toyonly, and have had to send it back once for what we thought was an injector wire in the wrong pin. Cliff and Justin are great guys, but I need more opinions on what is really going on.
i have spark, fuel to the rails, but no combustion. i CAN'T get this beyotch to fire!
Any ideas?
Old Jul 13, 2011 | 05:20 PM
dntsdad's Avatar
Usually maf issue with these symptoms.
Old Jul 13, 2011 | 05:27 PM
tacovr6's Avatar
clean the sensor, or check plug?
Old Jul 13, 2011 | 05:52 PM
vital22re's Avatar
totally a bro
Check compression. Last guy I helped did the timing belt but was off a couple teeth. A weak compression pointed me to that. Have you checked for codes? How do you know you have spark ? Fuel in the rail doesn't mean you have fuel in the cylinders. After cranking for a bit pull the plugs and look at the condition.
Old Jul 13, 2011 | 06:26 PM
tacovr6's Avatar
timing is most likely off, I changed the belt, but didn't get it perfect. will it not start with the timing a few clicks off? It runs if i shoot gas into the plenum.
for some reason my obd2 port isn't working??? scanner isn't reading it...
i know its getting spark because i have tested with a extra plug.
I don't know that it is getting fuel to the cylinders, I will pull a plug to check.
thanks for the pointers.
Old Jul 13, 2011 | 07:58 PM
vital22re's Avatar
totally a bro
If it runs when you spray it, chances are something with your maf isn't working and kicking on the fp through the COR. Try bypassing and hotwiring the fuel pump and see if it runs.
Old Jul 13, 2011 | 08:02 PM
dntsdad's Avatar
I think he meant kicking OFF the FP.
Old Jul 14, 2011 | 04:51 AM
tacovr6's Avatar
should the fuel rail have pressure when I crack it open? I cracked it open and turned it over, no fuel is coming from the main line. I am going to try and bypass the COR and hotwire the fuel pump.
Old Jul 14, 2011 | 06:53 AM
tacovr6's Avatar
hotwired the fuel pump and it runs like a champ! now what are my options? what do i need to do to fix this issue? use a 3.4 COR, or do I just have a bad 3.0 COR? lead me in the right direction knowledgeable ones.
So if I hotwired and it runs, what is my issue? I am kind of lost. Runs great, but holy hell is it loud!
80Truck
Oct 12, 2025 07:25 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
TDonkey
Jul 26, 2015 10:14 AM
toofly1999
Jul 25, 2015 07:09 PM
msane99
Jul 17, 2015 10:13 AM
