3.4 swap and regear ?
Old Jun 24, 2011 | 08:07 AM
anthony1's Avatar
Anyone else has 5.29 gear with the 3.4 swap? is it too low? Do I need to regear to 4.88?
Thanks
Old Jun 24, 2011 | 08:16 AM
DeathCougar's Avatar
Depends on several factors.
What size tires are you running, what is you overall goal with the truck, etc etc.
I am starting my 3.4 swap this weekend, and I am running 4.88 gears in my axles.
Old Jun 24, 2011 | 08:33 AM
hamish_18's Avatar
I have the 3.4 in my 4runner now, and I also have 5.29's with 35's. I don't like it on the highway. It is to low imo. I wish I would have gone with 4.88's. There is plenty of power to pull 35's even with 4.10's. But it was just a tad high for me driving around up in the woods. I went with 5.29's because I already had a rear end setup from when I had my truck. Don't get me wrong in the woods, its great.
I am currently trying to source an r452 tranny, or at least the 5th gearset from one, so that I can get my overdrive to 30%. This would put me at around 2100 to 2200 rpm's at 60 or so. Which will be much better.
Hope this helps ya.
Old Jun 25, 2011 | 07:08 AM
RobD's Avatar
I'm running 4.10s with my 33" tires and it's a decent combination. I would think 5.29s would be really low, depending on your tire size.
Old Jun 25, 2011 | 09:57 PM
anthony1's Avatar
I got 5.29 /35's now. I recalled seeing 3.4 w 31 & 4.30 instead of.4.56 as factory standard. Im not sure if the manual trans are the same as ours or not.
appreciated the inputs.
Old Jun 25, 2011 | 10:11 PM
vital22re's Avatar
totally a bro
3.4 with 265/75/16's and 4.30. Its already better for mileage than the previous 4.56 gears i had. I may not have the go off the line that snaps your neck, but I can now go farther on a tank of gas.
Old Jun 27, 2011 | 06:20 PM
tirogers's Avatar
i have 4.30 with 33" and 5speed and according to my calculations is VERY close to stock 3.4 ratios from the factory
Old Jun 28, 2011 | 05:48 AM
anthony1's Avatar
Sounds like I need to regear or get bigger tires...36 0r 37...
Towing with 5.29 should be great though.
Flying91
45
Apr 11, 2024 04:39 PM
LosPatosDelSur
23
Mar 12, 2021 03:08 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
93toyoguy
Aug 2, 2015 07:41 PM
94whiterunner
Jul 12, 2015 07:15 PM
