3.4 swap maf issues
Old Mar 29, 2011 | 09:37 AM
94RUNNER88!'s Avatar
3.4 swap maf issues
So i have 99.9% completed my swap and heres where im at. I have a 96 tacoma engine 5spd and its in a 94 4runner i used the ORS swap kit for wiring. So at this point whats going on is i have an issue running the truck it will start idle for maybe 10 seconds and then sputters out.
My question is i swapped to the 4 wire throttle body/ TPS and that seems work and need to know what part number people are using on their swaps for the MAF and if anyone else has had this problem and what they did.
Also in addition to that if anyone can tell me how to hotwire the fuel pump so i can rule that out as well.
I plus when its starts if i hold the key on and rev the truck it revs clean and smooth to the rev limiter. BUT if i dont hold the key and try to rev it it dies immedietly im sure this is simple and im just over looking it.
Any help would be appreciated thanks all
Old Mar 30, 2011 | 01:17 PM
hamish_18's Avatar
make sure you have power going to the MAF. when you were wiring it up, the +B wire needs to be spliced to 3 wires. It is the W-R wire. one should be coming from stock body harness, and from there it will go to the ecu, and there will be another w-r wire going out to the engine. That is what powers like the maf, and injectors and stuff. What you are describing sounds like the MAF not getting power.
Old Mar 30, 2011 | 01:59 PM
Well heres the issue with that i have not done any custom wiring at all but i have it running now and its does well the issue was no fuel/ so i bypassed the COR temporarily and this is my new issue. when i rev the truck with the clutch in it sounds awesome and seems like the reason everyone swaps to this motor its just strong. but when i am driving it under a load it will rev to right around 2500-3000 rpms (no tach mod yet, guessing) but close to there it falls off no sputtering no shaking kicking nothing just sounds like it has no idea what to do. and it sucks so bad too because it pulls so hard to that point
Old Mar 30, 2011 | 02:11 PM
I used a ors harness and everything on the harness isnt exactly color coded so im not sure how to attack this now PLEASE HELP ME i am setting on a $4000 paperweight at this point. and with some of the gurus/trouble shooters here someone should be able to nail this down with me.
Old Mar 30, 2011 | 03:00 PM
91SR5PU's Avatar
i would test to see if you have a bad MAF. You turn your truck to the ON position and take a voltmeter. put the positive probe in the VG terminal and the negative in the E3 terminal and blow through the MAF. if the voltage fluctuates then its good if it doesnt you got a bad MAF
Old Mar 31, 2011 | 06:02 AM
Runnerfan's Avatar
Sounds like what mine did at first. Check the power at the sensors B+ wire, I think they are white with a blue stripe. Also checking the STA wire at the ECM make sure it only gets 12v when the key is in the START position.
Old Apr 1, 2011 | 09:05 AM
hamish_18's Avatar
Also have you hooked up the obd2? I would definitely check that.
Old Apr 1, 2011 | 01:46 PM
bmcnutt's Avatar
My 2000 4 runner would not rev over 3000rpm & it was the crank sensor putting it in limp mode
Old Apr 2, 2011 | 09:45 PM
Hey guys apologize for the delay in updating this issue but i have been out smoking my 35's off the truck screams its unbelievably fast.So the issue was the wrong computer completely i will get back to you on the full part number but for a 96 tacoma motor running the 4 wire TPS the last 3 digits in your computers part number should be 290and i actually had 090 so put the computer in and got it all put back together and man what a freaking motor theres no way im going to get tired of hearing that intake suck the life out of my filter. thanks for all the help and i will update the new issues once i get the TRD SUPERCHARGER installed that i just purchased.
Old Apr 5, 2011 | 07:53 AM
hamish_18's Avatar
Nice! Congrats man!
Old Apr 5, 2011 | 03:53 PM
Hey thanks man all is well so far, Im putting the supercharger on hopefully beggining of next week. Then the week after that tearing it down to put my dana 60 in the front and my 14 bolt in just waiting to get my detroit for the 14 bolt right now. I think its going to be a beast with the supercharger, full size axles, lockers front and rear and the addtion of my new 40" iroks stay tuned
Old Apr 6, 2011 | 02:45 AM
Ride4Fun's Avatar
Hey 94Runner, your are going to love the 3.4, congrates on the swap.
You say you are going to full widths and 40's, what are you going to do with the 5.29's and 35's that you are running now? If you are going to sell them, let me know, I am only a couple of hours from you.
Old Apr 6, 2011 | 03:24 PM
honestly when i complete my swap you can have the third member the fron ifs and the tires because i like being generous and helping people PLUS my wife doesnt like alot of stuff laying around
Old Apr 6, 2011 | 10:33 PM
tirogers's Avatar
Wow generous guy! I'm staying tuned! PICS PICS PICS!!!!
I cant believe how fast mine is either. My girl has a 02 4runner auto and it feels like a slug! Mine a 5speed with 4.30 gears, electric fan setup,31's and 33 tsl's tomorrow!
Where did you find the supercharger?
Old Apr 7, 2011 | 12:08 AM
vital22re's Avatar
totally a bro
the sc is not a good idea on an ecu that older than a 97. Those early ecu's did not respond well to controlling the timing and fueling needs of a sc. Just so you know.
Old Apr 19, 2011 | 05:02 PM
believe it or not the first gen superchargers aren't that bad with the first gen computer. but i have already ordered the components from URD timing controller fuel controller and 7th injector so i should be okay once i come up my tuning solution from a tuner around virginia beach
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
94whiterunner
Jul 12, 2015 07:15 PM
