Question about Powersteering line
Old Oct 19, 2010 | 01:12 PM
Ahbustae86's Avatar
I see some of you have sleeved and welded your lines together. What material did you use to sleeve the joint? Brass, Galvanized...........? Did you guys MIG weld them or solder?
Old Oct 19, 2010 | 06:35 PM
dntsdad's Avatar
I just used some steel tubing from Lowes. I had to drill out the inside of the pipe a bit for the power steering line to fit snug in there.
I then mig welded it. Tig would be better but I have no access to that. My first attempt leaked badly, which I didnt know until the motor was started and PS fluid shot everywhere. Second attempt worked fine and is still holding.
Old Oct 19, 2010 | 09:14 PM
Ahbustae86's Avatar
dntsdad- Thanks man. Is the steel tubing in the plumbing area? I only seen brass, galvanized and copper in the plumbing section.
Old Oct 20, 2010 | 05:25 AM
dntsdad's Avatar
Mine was in the hardware section where the gate hinges and stuff are. The have a rack of various flat bar, tubing, etc. They have steel and aluminum.
Old Jan 7, 2011 | 01:45 PM
yodathespian87's Avatar
I re-used the old 3.0 one and cut the tab off of the end that goes to the 3.4. Works, no leaks as of yet.
the1998sr5
15
Jul 14, 2020 08:35 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
