Differences in Tacoma ECM
Old Jun 1, 2011 | 06:29 PM
Houston5's Avatar
Can anyone tell me the differences between a 98 and a 96 Tacoma ECM.Both are for 3.4 4x4 manual trucks.(96)#89661-04220,(98)#89661-04410.Thanks for any info.
Old Jun 1, 2011 | 08:31 PM
NIGHTCRAWLER541's Avatar
The plugs differ between those years. What are you trying to do/fig out?
Old Jun 2, 2011 | 02:55 AM
Houston5's Avatar
I should have put that in the post. I am doing a motor swap in to a 89 4runner. I have the motor and harness from a 98 taco but no ECM. I can get the correct plugs from the Yota warehouse here but I was unsure if the ECM itself would work
Old Jun 2, 2011 | 07:37 PM
hamish_18's Avatar
yes most any ecm will work with any 3.4 motor. the major obstacles are the sensors. I think the three big ones are MAF, TPS, and o2. in the newer years the o2 goes to an A/F meter. MAF design changes. and the TPS has 3 or 4 wire ones.
More specifically, the difference between 96 manual and 98 manual taco ecms/motors. Should have same TPS, both will use the same o2, and the MAF will be the same. BUT!!! the wiring for the MAF will be different. Same plug. wires are just in different positions on the plug... Everything else should be plug and play. Well hehe except for the plugs being wrong on the ecu, but you already knew about that.
Old Jun 3, 2011 | 02:29 AM
Houston5's Avatar
Thanks Hamish I am having a hard time finding the exact on for a 98 but have found one for a 96 so I wanted to make sure. Thanks again
Old Jun 3, 2011 | 04:19 PM
mosk's Avatar
If you haven't already seen it, the document I compiled on Tacoma ECU pinouts may be helpful:
https://www.yotatech.com/forums/f160...inouts-215718/
-Jeff
Old Jun 3, 2011 | 06:20 PM
Houston5's Avatar
ECU pin out
Yes Sir Jeff I have looked at almost every tear that is compatible for the 3.4.And also THANK YOU for all the work you and everyone else has posted to help everyone build or keep our great YOTAs on the road.
nonstop
Jul 24, 2015 06:29 PM
PureTacoma_Tundra
PureTacoma_Tundra
Jul 23, 2015 11:20 AM
94yotaMI
Jul 21, 2015 05:47 AM
94whiterunner
Jul 12, 2015 07:15 PM
Poncho0206
Jul 10, 2015 06:21 PM
