Reusing the 3.4 oil baffle plate
Old Jun 29, 2011 | 10:16 PM
Taco Burrito's Avatar
I'm planning to re-use the 3.4 oil baffle for my swap. I've cut one of the necessary holes into it for the oil pickup, but was wanting to know if it's okay to completely cut off the corner where the other leg for the oil pickup bolts through. I want to cut along the yellow line. Is that bad? What has everyone else done for this part?
Old Jun 30, 2011 | 10:05 AM
hamish_18's Avatar
that is the wrong one to cut off anyways. But you don't need to cut it off. Just cur the lip off. And you will want to cut the left side one down.
Old Jun 30, 2011 | 05:29 PM
I've double-checked about a dozen times and I believe I marked the correct one to cut off. But regardless, if only the lip is cut off, then how does the top part of the pickup form a tight seal against the engine?
Old Jun 30, 2011 | 06:08 PM
vital22re's Avatar
totally a bro
Hamish is right. You grind the lip off of it and it will work. I even have the bolt there. Just tighten the two bolts for the pickup before you tighten the mounting bolts for the pickup.
It's also the bottom left tab. Not the top one.
Old Jun 30, 2011 | 08:54 PM
OMFG, am I totally missing something or are you guys on something?
Here's what it will look like when I install it. The same corner that I marked in the first picture is the same one that needs to be modified here.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
v_man
Jul 23, 2015 04:01 PM
94whiterunner
Jul 12, 2015 07:15 PM
