removing old AC system
Old Jun 28, 2011 | 08:47 PM
anthony1's Avatar
How did you guys handled the old AC system? Did you undo the compressor from the engine and re-attach it to the 3.4 or let the gas out and remove the AC lines?
Old Jun 28, 2011 | 09:56 PM
dntsdad's Avatar
I undid mine and used the 3.4 compressor. In hindsight I wish I would have kept the 3.0 and broken the seal.
Old Jun 29, 2011 | 11:54 AM
NytWolf's Avatar
You mean recover the refrigerant.
Old Jun 29, 2011 | 12:22 PM
anthony1's Avatar
Well, to keep the greenies off my back, I was going seperate the 3.0 compressor from the engine and use it with the 3.4.
Has anyone here done that?
Do I need to use the bracket from the 3.0? or use the one on 3.4?
Old Jun 29, 2011 | 12:34 PM
NytWolf's Avatar
I ended up using the compressor from the 3.4 and the lines and plate from the 3.0. The reason why I didn't use the 3.0 is because of the pulley. If you can change out the pulley (requires pulling off the clutch), then you can use the 3.0 compressor.
Old Jun 29, 2011 | 01:06 PM
hamish_18's Avatar
pull the 3.0 compressor and use it on the 3.4, you need to use the 3.4 mount. Pulling the pulley off was easy. Just have to follow the fsm. it comes right up. You use a longer bolt per fsm and screw it in. I used an impact slowly. it pulls right up. This way you keep your refrigerent. If you have r12 you really don't want to lose it
Old Jun 29, 2011 | 05:25 PM
808-3VZE's Avatar
3vze ac compressor is a v-belt.
5vze ac compressor is a 4 groove serp belt.
best to use 3.4 compressor
Old Jun 30, 2011 | 10:12 AM
hamish_18's Avatar
NO, 3.0 compressor and 3.4 compressor are the same. the plates for the hoses are different, and the pulley's are different. That is all. Pull the pulley off the 3.4 compressor, and use it on the 3.0. Keep the system intact. Cheaper that way.
Old Jun 30, 2011 | 08:04 PM
just call me smithy's Avatar
x2 thats what i did been working ever since.
Old Jun 30, 2011 | 11:01 PM
anthony1's Avatar
I've decided to keep the 3.0 compressor. I'll change out the pulley and the tensioned pulley.
Do you still need the tension adjustment pulley?
Old Jul 1, 2011 | 08:02 AM
hamish_18's Avatar
yes you will need to use the 3.4 mount. So just keep the serpentine tensioner on it. Just swap clutch and pulley onto the 3.0 and mount it to the 3.4 mount. you will be good to go.
Old Jul 1, 2011 | 02:43 PM
anthony1's Avatar
Thanks. I'll take some pics ...
Flossy
Aug 5, 2015 05:14 PM
TJWilly
Jul 31, 2015 02:05 PM
Esibnitsud
Jul 30, 2015 08:21 PM
jjrbus
Jul 19, 2015 02:06 PM
