Vac hoses stumped...
Old Aug 26, 2010 | 10:25 AM
dem0nk1d's Avatar
okay so the time has come for my bi-yearly smog. i need some assistant on hose layout for the 5vz. i've attached some pictures, and believe i have everything correct but one hose, which is a little check valve on it.... so where does it go, and also what's broken off my vsv plug.
Old Aug 27, 2010 | 10:00 AM
hamish_18's Avatar
I believe that is just how they look. for the vsv. the vacuum tube coming from the front of the intake is for the 4wd vsv's I believe. And the top of the throttle is for egr stuff if I recall. looks almost like that host was put there to stop a vacuum leak from leaving them un plugged. both of mine are plugged right now.
Old Aug 30, 2010 | 08:58 AM
dem0nk1d's Avatar
So the line that's come from the front of the intake manifold should plug, with the check valve should plug into some kind of 4WD VSV. Oh damn. I don't have that at all. Maybe i can put a rubber nipple over it and call it a day. And the REF will pass the truck.
Old Aug 30, 2010 | 12:02 PM
hamish_18's Avatar
I don't see why not. if you don't have the Automatic differential disconnect. But I am positive the front one on the intake is for 4wd. Mine has a tee there with the elbow going down to the power steering pump idle up vsv or whatever it is.
Old Aug 30, 2010 | 02:40 PM
dem0nk1d's Avatar
I'll be heading to the state ref next Thursday. I have a week to get the new cat installed...
So will see.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
wberry85
May 17, 2016 05:45 PM
kcaudill
Oct 10, 2015 02:39 PM
taraf
Sep 25, 2015 02:57 PM
