oil dipstick location...
Old Dec 1, 2010 | 08:52 AM
murphyz's Avatar
i have an 99 tacoma 3.4 trd OR
and it has a dipstick hole on the driver side right behind the oil filter...
can i use this hole instead of drilling the plug out on the pass. side?
Old Dec 1, 2010 | 09:04 AM
waskillywabbit's Avatar
Passenger side?
I bought a bung with a hole in it for the dipstick tube and just swapped them out. Then tapped the original with M14 tap, screwed in a bolt with some RTV done. Pics on my build thread.
:wabbit2:
Old Dec 1, 2010 | 02:22 PM
hamish_18's Avatar
murphyz the oil dipstick is already in the correct location if it is BEHIND the oil filter. if its in front as in, it goes through the oil pump housing, then you would need to change it. Though off subject does anybody know why you even have to worry about this in the first place??
Old Dec 9, 2010 | 10:48 AM
theMonch's Avatar
I think it has to do with the oil pan and dipstick match-up. The motors that have the dipstick in the "wrong" location used a different pan that would not work with the suspension, etc. Therefore when you switch the pan, you need to switch the dipstick to match.
Old Dec 9, 2010 | 11:05 AM
murphyz's Avatar
thank you any tricks to plugign the old hole? tap and bolt it shut?
Old Dec 9, 2010 | 03:09 PM
dntsdad's Avatar
Yup!! Different sumps
Old Dec 9, 2010 | 05:38 PM
murphyz's Avatar
cool cool. time to plug a hole!
Old Dec 10, 2010 | 04:33 AM
UKrunner's Avatar
Mine had the hole at the front of the block. All I did was cut the original 3.0 dipstick down about 8 inches and used it to plug the tube. Why go to the trouble of all that fab work, tapping and sealing if you dont have to? Admitted, it looks cleaner without the additional useless dipstick.
Old Dec 10, 2010 | 04:52 AM
You have to swap the pan anyway and while it is apart doing what I did took maybe 15 minutes. It's done right and looks factory.
:wabbit2:
Old Dec 20, 2010 | 09:00 AM
My hole is behind the oil filter... But... I'm running the 3.0 pan, pickup tube and baffle. I'm "hoping" I'll be okay... I'm figuring I'll just put the correct amount of oil in it and see where it ends up on the dipstick. If it's off, I'll just engrave the dipstick with my new level basically.
Old Dec 20, 2010 | 09:29 AM
theMonch's Avatar
As long as your running the 3.0 dipstick and tube along with that 3.0 pan/pickup/baffle combo, you'll be good.
Old Dec 20, 2010 | 02:35 PM
Not sure which dipstick I've got to be honest... The motor was previously in a older pickup but was running the T100 3.4L pan and setup. I had to switch to the 3.0 setup though because of my steering setup clearance issues. I'll make sure to pull the dip stick from my old engine before the scrap guy takes it. I'm not letting the old motor disappear till I'm 100% sure the new setup is up and running correctly. Even then I'm going to strip all the accessories I can and ebay them or something...
Thanks for the reply! I appreciate it!
Old Dec 20, 2010 | 07:45 PM
theMonch's Avatar
No prob. The 97 T-100 3.4 5-speed IFS pan that was on my donor was the identical pan that was on my '88 3.0 5-speed IFS. (I think they might even be the same part number).
This led to me having a direct drop-in without any pan/disptick/pickup/baffle changes whatsoever. (I never even took the pan off it).
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
dumpster84
Apr 30, 2016 06:03 AM
93toyoguy
Aug 2, 2015 07:41 PM
adammtb
Jul 27, 2015 11:57 AM
calderp
Jul 27, 2015 09:58 AM
