i have a few questions ab my 3.4 swap... pls
Old Jan 20, 2011 | 06:29 PM
90tonka's Avatar
well to start i have a 1990 std cab 3.0L 4x4 5speed.
just got a: 01-04 3.4L w/ full motor and under dash harness and ecm...
questions:
1. would headers clear my tortsion bar?
2.can i ran the motor W/ its 3.4 motor mounts?
3.am i better off using and converting my 3.0 underdash harness? or use the 3.4 unederdash harness?
4.can i use the same fuel line and fuel pump?....
any help would be very helpful thanks
5.are all clutch accesories interchangable?
flywheel,pressure plate, clutch.. ect ect...
Old Jan 20, 2011 | 07:18 PM
just call me smithy's Avatar
Originally Posted by 90tonka
well to start i have a 1990 std cab 3.0l 4x4 5speed.
Just got a: 01-04 3.4l w/ full motor and under dash harness and ecm...
Questions:
1. Would headers clear my tortsion bar?
it's hard to tell, i'm sure you would be able to mod them to fit with a bit of grinding
2.can i ran the motor w/ its 3.4 motor mounts?
the 3.4 mounts are a little to tall if i remember right. I used the 3.0 mounts and they works fine
3.am i better off using and converting my 3.0 underdash harness? Or use the 3.4 unederdash harness?
use the 3.0 dash harness, theres only a few things that need to be re wired. It's not that difficult just time consuming.
depends, do you plan on super-charging? If not the 3.0 pump will do just fine, as for the lines they will work.
"red"]ether clutch will work , but the pieces are not interchangeable, if you use the 3.0 setup you have to use a 3.0 flywheel and a 3.0 clutch
Flywheel,pressure plate, clutch.. Ect ect...
[/color]
Old Jan 20, 2011 | 07:48 PM
90tonka's Avatar
thank u very much!
by headers i meant. the "obx 3.4 tacoma headers" not the stock. would after market ones clear?
2 yeah i figured id have to run the 3.0 mounts, it sits really high ( VVVV)
http://
3..the harness i have no idea what to convert and the threads on here and really confusing:/
and i have 3.0 pressure plate and flywheel... w/ a 3.4 6pad carbon race clutch... would that work?
thanks again! big help
Old Jan 20, 2011 | 08:08 PM
no the 3.4 6pad wont fit its to large for the 3.0 fly wheel, like i said either clutch will fit but you have to stay with what ever set up you go with, if you wan use the 3.4 6pad you need a3.4 fly wheel and pressure plate. what problems are you having with the wiring? some threads i used as guide lines were dntsdad's and oldgoats they by far have the best wright ups.
Old Jan 20, 2011 | 08:15 PM
90tonka's Avatar
ok cool got it 3.4 press. plat and flywheel thanks
umm the harness idk what to hook up or re-splice to connect to the motor... :/ any tips? or pics on how urs was done?
ill post pics of everything i have tmrw. if it helps
Old Jan 20, 2011 | 08:20 PM
have you downloaded the wiring diagram for both toyotas?
Old Jan 21, 2011 | 09:24 AM
90tonka's Avatar
no, i dont even know where to get that lol this is all new to me, im ure to working on muscle cars... not computers and all this crazy stuff lol
Old Jan 24, 2011 | 09:21 AM
90tonka's Avatar
can anyone help me wth the 3.0L harness conversion pls?
akamon808
3.4 Swaps
Dec 16, 2015 08:45 PM
coleypull15
Nov 3, 2015 07:41 AM
AndYota
Aug 10, 2015 09:19 AM
TJWilly
Jul 31, 2015 02:05 PM
Cplmike
Jul 8, 2015 08:47 PM
