Transmission Question
Old Aug 8, 2010 | 12:27 PM
Ahbustae86's Avatar
I have an automatic transmission from a 98 4runner that was sitting on the side for a while. Surface rust has developed in the bellhousing area of the transmission. The rust is on the metal in the back of the bellhousing pocket (best I can describe it). Do I have to knock it completely off to bare metal? Do I have to apply RTV gasket to the plate between the motor and trans before installing it together?
Old Aug 8, 2010 | 07:52 PM
cadman's Avatar
That metal part is the oil pump body. It won't hurt if it has some surface rust on it. Some Scotch Brite will clean it up nicely if you feel like cleaning it.
No, you don't need to use any sealant on that plate.
While you have the transmission out I would recommend you replace the oil pump seal & O-ring. Cheap & easy to replace.
Old Aug 8, 2010 | 08:53 PM
Ahbustae86's Avatar
Cadman- Thanks for the info. Your thread has helped me out a lot.
chuckross1957
Jun 28, 2019 10:19 PM
mskalmus
May 28, 2017 07:51 AM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
