Tach Mod?
Old Apr 12, 2011 | 12:50 PM
stihl460's Avatar
Tach Mod?
Ive searched high and low looking for an answer to which resistor to use. I know it is the 10K-Ohm resistor, but is it the 1/4 watt or the 1/2 watt resistor? Thanks for your time.
Old Apr 12, 2011 | 01:46 PM
Quick Draw's Avatar
According to Voltage = Current * Resistance, assuming 12 volts and 10k ohms, your current through the resistor will be 1.2mA. Wattage is Voltage * Current, so 12*.0012 gives you 0.014 watts that will be dissipated through the resistor. That's 5.6% of the 1/4 watt resistors maximum power dissipation. So go with either one really, but the 1/4 will be fine.
Sorry to get all technical on you... I was studying for my Physics 2 exam when I ventured over here.
Oh and I haven't done the tach mod yet, but make sure you know whether you're wiring it in series or in parallel...it matters quite a bit!
Old Apr 12, 2011 | 02:02 PM
vital22re's Avatar
totally a bro
well there is a write up that tells you where to solder it. And i've used 1/2 and 1/4, both work fine.
Old Apr 12, 2011 | 04:29 PM
dntsdad's Avatar
https://www.yotatech.com/forums/f160...l#post51339142
Old Apr 12, 2011 | 08:55 PM
deyzin's Avatar
The 1/4w maybe a better fit. I think its a tad smaller than the 1/2.
Old Nov 7, 2013 | 04:15 PM
Dude Man's Avatar
How about 1/8 watt?
I'm starting to get really frustrated with how difficult it is to find something so simple and common..
Have a whole bag of 1/8 watt resistors and I'd really like to get the tach working!
Old Nov 8, 2013 | 08:46 AM
SacRunner's Avatar
1/8 = 0.125
0.125 > 0.014
You should be fine
Old Nov 8, 2013 | 04:44 PM
Dude Man's Avatar
Yeah, figured that after I posted.. its only about 11% of the total capacity.
So for anyone wondering it doesn't matter if its 1/8, 1/4 or 1/2 watt.
TheBFA
Feb 15, 2020 06:55 AM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
oldblue
Sep 28, 2015 04:07 PM
Project90
Sep 24, 2015 11:40 PM
