Stock Reverse Lights- Trans- Wiring help
Old Sep 15, 2010 | 05:13 PM
th3rat's Avatar
So I bought a 91 4runner w/ the 3.4 swap from a 2000 Tacoma already done to it. The reverse lights do not turn on and there are many many wires that dead end in a ball of electrical tape in the engine compartment (there are no emissions devices in the rig, possibly no A/C).
What I can see is that the rear backup/reverse lights are wired Red w/ black stripe and white w black stripe. these wires thread into the drivers side body and disappear.
The reverse light switch on the Manual Transmission has a Red w/ white stripe and a Brown w/ Black Stripe wires coming off of it, but they terminate under the chassis.
If anyone knows where I can pick up the wires from the reverse lights, and which I should wire the trans reverse switch to, (and where to pick up 12v?) I think this will fix my problem.
Specifics on locations, connectors, wire colors, (pictures would be most helpful)
thanks
Old Sep 16, 2010 | 10:40 AM
UKrunner's Avatar
IH2 pin 8 should be connected to the trans connector pin 4. Black Orange.
IH2 pin 7 should be connected to the trans connector pin 8. Red White.
the1998sr5
15
Jul 14, 2020 08:35 PM
1994toyota
Jul 17, 2015 03:03 AM
mengquis
Jul 13, 2015 10:39 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
