3.4 swap with SC and no lift?
Old May 6, 2011 | 03:50 PM
mlrtime99's Avatar
Don't get mad I swear I've read through a ton of posts and can't find anything definite because everyone does it slightly differently. This is all for a '91 4Runner 4x4 5 speed. The IFS must stay.
Questions-
Can you swap in the 3.4 without a body lift AND the supercharger?
Do you have to swap oil pans with the 3.0?
Searching for a 3.4 I've heard pulling one from a T100 gives you a better fitting version, but you can only use an ECU from a 97-98, true?
Basically I just need the rules of the swap.
Old May 10, 2011 | 07:54 AM
hamish_18's Avatar
1. you will need to do something to clear the motor. Some can cut the middle bracing out, others have to cut a hole in their hood where the motor hits. some raise the hood up a little. Just get a small body lift man. Its not the end of the world.
2. Yes you will have to swap to the 3.0 pan. Honestly, I have been swapping the pickup, AND the tray thingy from the 3.0 as well. I have never seen a leaking oil pan on a 3.0, so I don't see why you couldn't use the sandwiched tray again. Just make sure you get a good seal with gray RTV on both sides.
3. A 3.4 is a 3.4. IF you get a 3.4 from a 2wd t100 then supposedly the pan will clear. If you already have the 3.0 junk, just use it man. It will make things easier on ya.
4. Search Search Search!!
Hope this helps. Good luck with the swap.
Old May 13, 2011 | 11:39 PM
tirogers's Avatar
I used the 3.0 "sandwitch" oil splash thing, and it sealed just fine, not one leak! Knock on wood!
2000mi so far and not a single problem
Old May 14, 2011 | 09:54 AM
vital22re's Avatar
totally a bro
the sc sits up taller than the intake manifold on an n/a motor. You will have to cut the hood if you don't want to do a body lift.
Old May 14, 2011 | 03:49 PM
mlrtime99's Avatar
Thanks guys, I swear I have searched and read my ass off. People just do this swap so many different ways. Seems with no body lift I'll need to cut but can cover that up with a sport scoop, I'm hoping the SC fits as well.
Old May 20, 2011 | 05:59 PM
theMonch's Avatar
Mmost likely you will have to trim the inner support structure and cut a hole/ w scoop if you do not want to go body lift. My '88 needed a bit more trimming and clearancing than I have seen most 89-95's needing and it still fit under a "Tacoma-alike" scoop. There are picts at the end of my build thread in my sig.
If you get your donor from a 4wd IFS T-100 than no. You can stick with the pan that comes with it. I believe it is the exact same pan as the 3.0.
Yes this is true. Only the 97-98 T-100 ECU's are equipped to handle the supercharger's extra fuel requirements, and even then, I would recommend the URD fuel upgrade.
Old Jun 10, 2011 | 08:35 AM
calipatient's Avatar
this is an easy article to help get you started if you havnt already...
http://www.andrewzook.com/content/view/22/37/
I am doing mine with supercharger and plan to use the 2" body lift
Flying91
45
Apr 11, 2024 04:39 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
coffey50
Jul 28, 2015 10:55 AM
94whiterunner
Jul 12, 2015 07:15 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
