PDA
View Full Version : 3.4 Swaps
Pages : 1 2 3 [4] 5 6 7 8
  1. wiring harness
  2. 3.4 Swap Time!
  3. R150F inspection plate ???
  4. does the ecu need to see the vehicle speed?
  5. dual friction centerforce clutch for 3.4 and 3.o throwout bearing...
  6. 99 4Runner Theft Deterrent System, Do I Have It?
  7. 3.4 swap in '92 4runner + some build up
  8. What size is fuel hard line on frame?
  9. tach mod for 1985 22re?
  10. 97 t100 automatic to 5spd swap
  11. My 3.4 swap is starting back up!
  12. a340f automatic trans won't hold in 1st
  13. 1993 Pickup 4x4 M/T 3.0L - 1996 T100 4x4 M/T 3.4L
  14. 3.0 pickup to 3.4 t100 conversion
  15. 22re to 3.4
  16. Headers and Dual Exhaust
  17. wiring help/possible build thread....22re --> 5vz
  18. best year?
  19. 3.4 swap harness question
  20. Went on TIS no EWD's for a 1993 Pickup need help finding
  21. Oil Capacity
  22. Tricking 2000 3.4 ecu
  23. Question on 1996 r150f trans
  24. Good price for a 3.4 with misfiring cylinders?
  25. What kind of solder for electrical
  26. 1996 3.4 2wd auto engine into a 1991 3L 4x4 manual
  27. ECU to mate with 2001 4Runner Auto harness
  28. ADD wiring
  29. lead on a 1998 T100
  30. Need 89 EWD for 3.4 swap
  31. Is this the evap/return hose?
  32. 96 4runner EWD
  33. ecu gods!
  34. Need A/C help, nothing has fixed it! 3.4 swap
  35. How many cranking amps for a swap 3.4?
  36. Donor Vehicle - Worth it???
  37. Messed up with the hurry.... Oil Capacity after 3.4 swap?
  38. Power steering question
  39. 3.4 swap 2000 tundra ecu auto
  40. ac comp. oil?
  41. where to get dipstick tube adapter for 3.4 engine
  42. What to swap in? 99 4runner or 96 t100?
  43. 3.4 swap fires but won't run
  44. 3.4 3wire to 4wire tps adaptor
  45. 3.4 almost completed, but different MAFs give different codes!! Why??
  46. Just dropped off 94 4runner With Toy only Swap
  47. I hate wires
  48. Need help with A/C
  49. Back... 3.4 swap running rough
  50. 5 speeds
  51. Another CARB legal 3.4L Swap!
  52. 3.4 swap almost alive!
  53. 3.0 to 3.4 swap help
  54. 3.0 intake bolt to 3.4?
  55. 99 3rz to 3.4
  56. 3.4 swap misfiring. thinking coil packs
  57. Need 3.4 V6 Crankshaft Dimension!
  58. Finally started but few issues
  59. Anyone finished Cruise Control with 3.0 Motor Type?
  60. Exhaust system after the swap
  61. guys with working AC, do you have a clicking noise?
  62. transmission swap?
  63. HELP 3.4 motor swap wiring
  64. Help with my 3.4 swap
  65. 3.4 swap parts list
  66. Confused with rear o2 elimination/simulator wiring
  67. headers
  68. new 3.4 thottle cable and still high idle
  69. Anybody done a 2WD 3.4 swap?
  70. Gas Mileage, gears, tires
  71. logistic forum problem after swap
  72. need 3.4 swap wiring help
  73. Identifying wires
  74. EVAP system n/a
  75. My personal favorite swap pic!
  76. Oil pan swap questions
  77. vent on passenger side
  78. Jeremy's 3.0 to 3.4 Swap
  79. alternator wiring
  80. No timing adjustment?
  81. ECM/MAF wiring
  82. 2 speed sensors?
  83. Vapor pressure sensor, VC
  84. need a 3rd opinion/steamin issue
  85. gasket between the exhaust and crossover pipe
  86. Mounting OBDII port
  87. main fuse box position
  88. How to speedo swap?
  89. Throttle by wire
  90. 84 PU 5vz swap
  91. OBD port wont communicate
  92. 22re to 3.4L in a beastly 85 4runner on 40" iroks :)
  93. tranny help
  94. 3.4 casting numbers
  95. Does 95 4R need fuel pump relay mod?
  96. Rolled my 93 with 3.4 swap now running poorly
  97. 96' T100 3.4L motor question
  98. Need 3.4 fan clutch
  99. 3.4 maf conversion
  100. 92 Ewd?
  101. SR5 Gauge swap tach not working
  102. Jim's used Toyota truck parts Denver, CO
  103. 87 22r to 3.4, here goes nuthin! swap
  104. can you remove the cross over with trans in truck?
  105. a340f Shift lock release
  106. is my wiring correct? check it out..
  107. Anyone need a crossover
  108. what is this connector for?
  109. Auto swap Park Neutral Switch wiring Question
  110. '03 Tacoma 3.4L, 5-Speed - to - '95 4Runner, Automatic Swap
  111. Tach ?
  112. Passed the referee!
  113. Donor Vehicle or Piece Together?
  114. 3.4 swap ecm/ecu question.
  115. ? about wire from battery to fuse box
  116. Alternator heatsink and plugs swappable...
  117. 3.4 5vzfe swap headers
  118. 3.4 swap smog legal in ca.?
  119. 3.4 codes 120-130-420
  120. Swap wont start (fuel issue)
  121. How to: A/C for your 3.4 swap
  122. 3.4 Power Steering!!!
  123. 340h to 340f with column shift....
  124. Getting ready to cut the hood and install hood scoop and...
  125. Well I got it running
  126. wiring and vacuum hoses for evap stuff
  127. help me with the wiring. think i have it but not sure.
  128. 88 4runner Not getting power from ignition switch (starter relay)
  129. Finishing 3.4 Swap Codes to go: P0135 P0340 P0505
  130. something happened...misfire
  131. swap 94 3.0 to 96 3.4 SC keeping 340h auto
  132. question on fuel pumps and wiring
  133. New guy tis search
  134. I am doing it 3.0 to 3.4 swap with complete engine rebuild
  135. Help from someone who used 3.4 alternator!!?
  136. IT FIRED! (but I need help!)
  137. Bought my 3.4 to put in my 92 pickup 4x4 ex cab
  138. can i use 3.4 clutch kit with a 3.0 tranny?
  139. can i make my crossover for my 90 in the 99 frame?
  140. QuickSilver's 3.4 swap 99 runner into 90 runner
  141. Will auto motor convert to manual?
  142. 3.4 swap runs for2sec before shutdown...
  143. 1999 Engine into 1988 4runner
  144. 1990 Pickup 3.0 to 1996 Tacoma 3.4 Swap
  145. 2000 3.4 in to 89the extra cab 4x4
  146. My 2nd 3.4 swap= no start
  147. Which radiator for 3.4 swap, 88-89 4Runner/88 Truck V6
  148. New Style EVAP question
  149. Do I need to wire P/N switch?
  150. Is this a good deal for a swap?
  151. Can i use auto harness and auto ecu with 5speed trans
  152. 3.4 Swap isn't starting now
  153. Temp gauge does funny thing after swap
  154. 1980 pickup with 3.4 swap, ever done?
  155. Havent started my 4runner in 6 months. What to do.
  156. 97 2WD 3VZ to 4WD 5VE swap
  157. Top shift or forward shift with automatic?
  158. 1990 2 Door 3.4 Swap
  159. 3.0 to 3.4 swap questions (exaust, wiring, ecm)
  160. P0758 code 97 4runner into 95 4runner
  161. Clutch, fuel line issues, and mystery sensor
  162. Shop to swap 3.4?
  163. T100 as donor for 3.4 swap
  164. stiffener plates
  165. 3.4 with an A440?
  166. If you have 3.4 Swap and SuperCharger... READ THIS!!!
  167. 3.4 swap wiring
  168. 3.4 swap...need help with wiring
  169. What power steering pump n lines did u use for 3.4?
  170. Headers for 3.4 swap
  171. 96 Auto meet 91 Manual...
  172. 3.0 to 3.4?
  173. 93 4runner 3.4 Swap-Let the journy begin!!
  174. Vasinvictor's budget 98/3.4/Auto into 95/3.0/Auto
  175. 3.4 swap o2 Sensors i need help /w wiring question
  176. 1989 yota 4x4 w/3.4l runs but dies unless the Maf is unplugged/plugged back in
  177. Etravoda's 97 Auto 3.4 Swap into 95/3.0/Auto
  178. Check out my possible donor
  179. Locked_SR5 22RE to 3.4 Swap
  180. Bend's 3.4 to 88 5speed 4runner
  181. 3.4 swap with custom wiring idea.
  182. 3.4 and tranny swap from pickup to 4runner?
  183. 22re man. to 3.4 auto/gear drive transfer case
  184. 3.4 swap into 91 3.0 4runner
  185. Whats the best performing air Filter and Exhaust for 3.4?
  186. How long did it take you do your swap?
  187. Overdrive not working
  188. 96 T100 auto IE1 and IE2 pin outs
  189. RPM vs MPH
  190. trd passenger drop headers on 3.4 in 90 p/u
  191. 3.4 swap EVAP hoses
  192. 1991 4 runner thinking of going to 3.4
  193. Gauge compatability
  194. 1994 Pickup 3.0 to 3.4 swap
  195. Post pictures of your 3.4 Swap Hood Scoops!
  196. Vss
  197. 93NMyotas 3.4 swap, recommendations please!
  198. 3.4 swap headers?
  199. Almost done with swap, wirings questions...(of course)
  200. 3.4 swap transmission questions
  201. A whole lotta clicking with the starter. [VIDEO]
  202. A different kind of crossover question...
  203. It runs and now need advice on tranny wires!!!!!!
  204. Not sure where this plug goes!
  205. ECM part numbers
  206. Burping system after 3.4 swap
  207. 22re to 3.4swap mas question
  208. Newest 3.4 swap, auto this time.
  209. superchiem's Toyota RV 5vz Swap
  210. Wiring for 4th Solenoid
  211. Relay Box Removal
  212. 3.4 swap stalling
  213. 89 4runner swap
  214. Hello YotaTech......newbie about to attempt this 3.4swap
  215. 3.0 to 3.4 auto tranny..
  216. Backup light not working-2nd gen 4runner
  217. Brakes / fuel smell / high rpms on highway
  218. High Idle Issue...
  219. Manual to auto swap, quick question
  220. Fueling issue, No start ??? HALP!!!!
  221. EVAP "clicking" when engine warm
  222. 3.4 Swap - Starting Issue (Wiring Q)
  223. 3.4l swap injector swap
  224. 3.4L supercharged
  225. auto ECU in Manual swap & CA smog
  226. Starter Trigger wire
  227. Batt cable to fuse box. & VSV wires
  228. 3.4 swap sputtering!!! HELP!!!!
  229. 5Vz into a 22re 4Runner
  230. Trans removal
  231. Keep Batt location and shorten Intake tube..
  232. 3.4 ultimate build
  233. power sterring pump cable
  234. 700+MI on swap HIGH IDLE ISSUE
  235. 3.4 questions
  236. Swap finished, brake issues.
  237. WIRING: Does the gauge have to match?
  238. 3.4 auto and ADD system wiring issues
  239. P1780 code
  240. 3.0 Starter in 3.4?
  241. Running Rough
  242. 1990 toyota pickup v6 manual receiving 2000 4runner v6 manual
  243. 2002 4runner 3.4 into 1998 Tacoma 5lug 3.4
  244. toyonlyswaps.com "swap in a box"
  245. 3.4 Swap 101
  246. 3.4 swap and SAS 91 runner
  247. 96 T100 swapped to 97ecm for 1st gen s/c. Now have code p0450. Any way to trick ecm?
  248. Where to buy pins?
  249. manual ECU with 3rows of pins
  250. Power steering lines?
