Does 95 4R need fuel pump relay mod?
Old Apr 24, 2012 | 12:22 PM
anthony1's Avatar
I don't know if my 95 4runner needs to change the wiring for fuel pump power or not? I thought I heard the fuel pump goes on when I turn the key.
Anyone did conversion with 95 trucks?
Old Apr 24, 2012 | 05:39 PM
dntsdad's Avatar
In my experience the fuel pump will not turn on with the key if you are using the 3.0 setup.
With the 3.4 relay, it will.
It should not matter as both will work. Saying that, I always have switched to the 3.4 style setup. Simpler IMO
Old Apr 24, 2012 | 07:23 PM
vasinvictor's Avatar
No conversion necessary. I used stock 3.0 COR setup.
Old Apr 24, 2012 | 09:02 PM
anthony1's Avatar
Thanks. I'll try the stock COR first then...
Old Apr 25, 2012 | 06:19 PM
anthony1's Avatar
Can I add 12V after the ignition to the lavender wire that goes into the "open circuit relay"? That wire goes to the pin 6 of IE1 connection on my truck.
It turns on the fuel pump.
Thanks
Old Apr 26, 2012 | 10:29 AM
anthony1's Avatar
I'll go ahead and provide answer to myself....
I was talking to someone about it. He said there's a reason to go through the FC pin and a relay. In the old days when your engine stops, the mechanical fuel pump would stop also especially in case of an accident. Today, we use electrical fuel pump which will continues to pump fuel even when the engine is disable if the key is left on. Apparently, there's some jolt detection which cut the voltage to the relay which turns off the fuel pump as a safety measure in case the fuel line is rupture due to an accident. I guessing that the jolt must be pretty big for it to work because it never did when I 4wheel the truck before. ......
I'll try to make the FC pin to a relay connection to work.
This also explained why some cars can not start after the accident. The ECU has to be reset to deactivate the jolt setting.
Old Apr 26, 2012 | 03:21 PM
vital22re's Avatar
totally a bro
If you rig it to run by the 3.0 system where it uses a signal from maf its fine. I've wired 6 swaps this way and none have any issues.
Old Apr 26, 2012 | 04:50 PM
QuickSilver74's Avatar
mine ran fine today with no changes to the factory wiring in the 3.0 relay. i was thinking i would need to change something out, i just tried it and it will fire up just fine
Old Apr 26, 2012 | 07:04 PM
anthony1's Avatar
The fuel pump works now. The FC in 96 T100 wiring is already in the E1-23. I guess the ends must've walked out or something when I plugged the connector in the first time. Same thing with the Coolant temp.
Just from looking at the wiring closer, it seems the FC actually goes to ground to turn on the fuel pump...is that right?
Old Apr 26, 2012 | 07:40 PM
the FC is a ground signal. you can use it to trigger the fuel pump relay
Old Apr 26, 2012 | 07:52 PM
anthony1's Avatar
I thought so. ...
Thanks.
Old Jan 3, 2013 | 02:35 PM
jood's Avatar
Need help. have 95 4runner 3.0. no power to fuel pump with key in on position. no power to fuel pump jumping B+ to FP. Putting direct 12v to fuel pump lead and the pump is fine. My thoughts [aside from correct diagnosis] is run a 12v lead directly to fuel pump that in only powered up when the key is the 'on' position. Anyone know if there's a danger in doing this? Or if there some other T/S i have not done?
Old Jan 3, 2013 | 05:01 PM
dntsdad's Avatar
Other than if your truck flips/rolls over and the fuel pump is still engaged thus pumping gallons and gallons of fuel everywhere, and then some guy throws a cigarette and ignites the whole thing and thus a busload of nuns happens to be driving by right then and you kill them and the 30 puppies they were taking to the animal shelter!!!!! Jeeezzz! Whats wrong with you??
Seriously dont do that for the above reason without the hyperbole and drama.
Do you have power to the larger blue/yellow?? (Cant remember) wire at the relay when the key is on? If not, find out why. Fuse, something not wired correctly, etc.
From there just hook up the relay. The green lead off the relay will go the FP on your ECM.
Maybe this will help?? About 3/4 down
https://www.yotatech.com/forums/f160...-101-a-239002/
Old Jan 4, 2013 | 04:40 AM
What a drama queen...
Seriously, don't do that. Hook it up the right way.
Old Jan 4, 2013 | 05:40 AM
vital22re's Avatar
totally a bro
You will not have power with the key on. The afm sends a signal to the COR to kick on the fuel pump when the flap inside the afm is moved by the suction of the motor running/turning over. Do you have 12v at the B+ with key on? Are you putting 12v directly to the pump at the pump? Or still at the diagnostic box.
Old Jan 4, 2013 | 03:02 PM
jood's Avatar
There is 12v at B+ with key on. Fuel pump works fine when 12v applied directly [at the pump] so pump is non-issue. there is 12v at FP in the diag box when engine is cranking attempting to start truck. and there is 12v at FP in diag box when truck is running. Does this sound like COR is bad?
Old Jan 4, 2013 | 03:03 PM
jood's Avatar
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
