Well I got it running
Old Mar 18, 2012 | 05:25 PM
Kentucky4runner's Avatar
Thanks to monch sticky and dntsdad sticky I got my t100 3.4 swaped in my 88 4runner. I was so glad it fired first try auto harness to man. Ecu is not to bad looking at all those ewd's will make your eyes cross. Still have to get exhaust on. My question is did they all have the evap box? my donor was wrecked on that side and it wasn't there it had a vsv on charcoal canister bracket and the back of the intake only have one vacuum hose not figured out with the little filter looking thing on it. I also can't seem to find but two evap wires at harness g/w r/w that hooked to the ones on the evap can. It non-egr also. It runs smooth the way it is though.
Old Mar 18, 2012 | 05:35 PM
anthony1's Avatar
Congrats! on the swap. You beat me to it.
I believe the EVAP canister suppose to release the vapor pressure in the fuel tank when it gets hot. It works with the ECU and water temp sensor. The charcoal canister suppose to clean the vapor before it released into the air.
The engine will run fine without that stuff for a while. I'm not sure what will happen if there's a lot of pressure built up in the fuel tank. I guess it can't be too good.
Old Mar 18, 2012 | 07:50 PM
vasinvictor's Avatar
I am not using an EVAP can. I just have the VSVs connected to the harness and tucked away. I pinched off the vent line and and using a vented cap. I have not gotten a CEL yet. Grats on getting it going. Post up some pics.
Old Mar 21, 2012 | 06:44 AM
So it idles great and not missing when I try to give it gas hard it stalls. But if i ease into it it will rev up fine. I think I am going to try a new fuel filter I dont think its getting enough fuel. It seems to get better the hotter the engine temp is. Also when you start it it will die unless you leave the key on for a few seconds before cranking. Like its not getting enough fuel pressure. It will always start fine on second try. Thanks for help guys this forum is great.
Old Mar 21, 2012 | 08:31 AM
Fernley1's Avatar
Didnt some T-100 3.4 have only 1 plug to the vaper canister?
Old Mar 21, 2012 | 01:46 PM
if so thats what i have and it was mounted on the canister
Old Mar 21, 2012 | 04:24 PM
i got it fixed after doing some digging it was the w/r wire ie1 b+ power not hooked to the other 2 w/r b/y
Old Mar 21, 2012 | 04:45 PM
Ha it got you too! Glad you figured it out.
Old Mar 21, 2012 | 06:14 PM
QuickSilver74's Avatar
where was this connection suppose to be made? the one w-r hooked to both the w-r and b/y together?
Old Mar 21, 2012 | 06:23 PM
Yes all 3 together
Old Mar 21, 2012 | 06:39 PM
good to know. i have a w-r coming from the original 3.0 body harness that i didnt know where it was going to go to. now i can look over my diagrams more carefully.
what functions did the w/r and b/y control?
Old Jan 22, 2013 | 08:02 PM
Snorkeld_Zuk's Avatar
Ok, I just got mine running, and I have this same issue. Runs, idles fine, but it bogs badly when you give it gas. If you gently ease into the throttle it will rev. 88 4runner 3.0AT swapped to MT, 3.4 from 95 T100 MT. The W-R wire (switched 12v) is hooked to the B-Y, but not any other W-R. What am I missing here? I haven't hooked up my DLC yet, but I planned on hooking the 12v power to it to this same circuit.
I tied the only other W-R wire (aside from the one in the 3.4 harness that goes to my evap purge solenoid) in to the circuit and it did not fix it. I'll have to look at this again in the AM
Old Jan 23, 2013 | 01:38 PM
My problem was no power at the Maf sensor. I would unplug it and see if it makes a change. If not I would say thats your problem. Makes it run in limp mode.
Old Jan 23, 2013 | 05:28 PM
Yeah I spent my morning on it. I found that I ran the W-R wire from the 3.4 harness to the evap purge vsv, but not back to the W-R IGN circuit. So yeah no power at the MAF, and P0100 code. Runs like a raped ape now.
the1998sr5
15
Jul 14, 2020 08:35 PM
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
coffey50
Jul 28, 2015 10:55 AM
calderp
Jul 27, 2015 09:58 AM
