WIRING: Does the gauge have to match?
Old Aug 19, 2011 | 04:02 PM
Taco Burrito's Avatar
I've got most of my wires sorted out and began repinning one of the harnesses when I came across a wire that was much thicker on the recipient vehicle than the donor. Is this an indication that I've made a mistake, or is it okay to solder the thin donor wire to the thick recipient wire?
Old Aug 19, 2011 | 06:50 PM
dntsdad's Avatar
What wire?
Old Aug 20, 2011 | 01:42 PM
Originally Posted by dntsdad
What wire?
It was the Tacoma ECU E5 pin 7 (green) to the 4Runner IH1 pin 22 which is a slightly thicker wire (black-red).
It's for the clutch start switch.
Old Aug 21, 2011 | 09:20 AM
dntsdad's Avatar
I took a look at the only Taco EWD I have and do not find a green wire that would be something that you would be splicing. Also, there should not be a wire from the Clutch start cancel that goes to the ECM. That essentially is handled inside the trucks wiring upstream of the starter signal wire.
The large B-R wire is IGN2 in the vehicle in the IH1 or IH2 (dont remember which). I cant see how you should be connecting that to anything related to the clutch start. You will use it, and it is OK to splice to a smaller wire, but I think that you may have something going in the wrong direction.
Old Aug 23, 2011 | 10:23 AM
anthony1's Avatar
You should try to use the same gauge or slightly larger. Smaller is not recommended.
If the wire is for the engine compartment, I'd look at the heat rating. You don't want the engine heat to melt the jacket and cause all kinds of shorts.
Old Aug 23, 2011 | 11:32 AM
dnt 'n ant: thanks for posting. I'm out of town and won't be back until next week. I'll follow up then.
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
LittleUgly
15
Jan 2, 2020 01:30 PM
zanzabar0
Oct 11, 2015 02:56 AM
Jdgarrison
Oct 1, 2015 05:22 PM
