what is this connector for?
Old Apr 10, 2012 | 03:43 PM
QuickSilver74's Avatar
attempting to get my swap ready to start and i have a connector that as far as i can tell, i will not be using any wires from. it is the small gray connector in the pic below. i think it has some of the functions of the evap system and the check engine light, both of which i will not be hooking up.
is there anything in there that i actually need for the truck to run?
Old Apr 10, 2012 | 04:27 PM
SacRunner's Avatar
That was II1 for my '96 auto 4Runner donor, but wasn't needed for my '91 manual recipient; that's the theory at least, I'm still a ways away from turning the key. That connector housed a lot of the auto wires and the ABS and cruise control wires, but on my '91 all the ABS and cruise wires "lived" entirely within body harnesses, there was no interaction with the 3.0 engine harness.
https://www.yotatech.com/51891254-post22.html
Of course, different years and models called connectors different names and probably moved wires around, check your EWD, it'll be in the "power source/electrical wiring routing/connecto.pdf"
Old Apr 10, 2012 | 05:13 PM
jd20phill's Avatar
Quick silver is correct. All pins in that connector II1 were for the ECT system. I didn't use it at all, and have the check engine and EVAP system. Just out of curiosity, why don't you want to hook up the check engine light?
Old Apr 10, 2012 | 05:21 PM
i am running an auto computer so the light would be on constantly
Old Apr 11, 2012 | 05:10 AM
vasinvictor's Avatar
My cruise control runs thru II1- a must have for me. Also, as above mentioned, the CEL, ABS, Park/Neutral switch, and COR (depending on how you wire this up)
some drunk guy
Aug 3, 2021 06:09 PM
Obmi
Sep 10, 2016 04:40 AM
mct75
Aug 22, 2016 01:24 PM
Obmi
Nov 24, 2015 11:37 AM
moparbay
Sep 3, 2015 12:48 PM
