96 T100 swapped to 97ecm for 1st gen s/c. Now have code p0450. Any way to trick ecm?
Old Jul 29, 2011 | 04:24 PM
Meangreen T100's Avatar
Hey fella's i have a 96 T100 that i am going to be installing a 1st gen(grey) s/c on the 3.4 have done some diggin n found that my
96ecm wont work, have swapped in a 97ecm , runs the same as norm but throws code p0450 (evap). I'm guessing the ecm dont realize my truck is not equipped with that system. Anyone run into this? Or have a trick to fool the ecm into thinking i do?
Old Aug 1, 2011 | 08:57 AM
hamish_18's Avatar
So your t100 has evap. It just doesn't have what one of the sensors I think? the VPS one? To resolve the issue, you would need to add that in. I honestly can't think of any way around it. Unless you possibly re-flash it? or just live with it. knowing that you have that code. And check it from time to time to make sure you have no others.
Old Aug 1, 2011 | 10:59 AM
Yea thats kinda what i figured, sounds like more messing with wires than needed!! I can live with the light on, it only throws that one code and runs great. Thanks for the reply pal!!! Supercharger is goin on this week! Wooo
Old Aug 2, 2011 | 10:20 PM
BamZipPow's Avatar
What did you do to swap that ECU in? Wanna share yer steps? Got any piccies? How long did it take you?
Old Aug 3, 2011 | 05:16 AM
Dont have any pics but i'll walk ya through, super easy the ecm on t100's are behind the pass side kick panel, just remove that n you will see it. There is 3 10mm bolts holdin it down, the plugs are the same (for m/t 4wd) ecm's only. Auto trans ecm's are different. Hope that helps a bit.
Old Aug 3, 2011 | 05:19 AM
Oh yea and timewise it took about 20 mins all said n done, the brackets fit the same on the 97 ecm just remove the black tape covering the screw holes. All ya need is a 10mm socket and phillips driver : )
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
taller1
Jul 16, 2015 03:00 PM
coryc85
Jul 6, 2015 04:07 AM
CJ94yota
Jul 3, 2015 10:14 PM
