a340f Shift lock release
Old Apr 14, 2012 | 02:28 PM
vasinvictor's Avatar
Calling on anyone who has the shift lock release working properly using the doner shifter and doner a340f. The only thread I can find any info about it is Mt.Goat's thread, but the pictures are too small to see what was spliced. The 98 EWD is not making any sense and colors are not matching up. Any help would be appreciated.
Old Apr 14, 2012 | 05:46 PM
ultimase's Avatar
Not much help on this one, I always thought the shift lock release was physical and not electrical. Odd that it suddenly stopped working though, have you taken a look under the car at the actual linkage?
Sorry might be completely off base on this one.
Old Apr 14, 2012 | 06:02 PM
QuickSilver74's Avatar
i always just disable the lock. really dont see the need for it.
Old Apr 14, 2012 | 07:19 PM
How do you disable the lock? Physically remove it? I'm not opposed to it. I've been pushing the button To this point.
Old Apr 14, 2012 | 07:52 PM
pop the cover off, see what is blocking it from shifting and remove it. my Xterra had a little lever that simply pushed off, my civic had a small plastic pin that i used a razor to cut off.
you could just rewire it to stay open but with being constantly on it may burn up faster. i prefer to just remove it and forget it
Old Apr 14, 2012 | 07:56 PM
That's just what I'll do then.
If somebody knows how to properly wire it up feel free to chime in. The wires going out of my shift lock to the solenoids match up with the EWD but the input wires don't match jack squat. I have a Y, R-W, R, L-W, and B for inputs.
I have an extra shifter I can play with later.
Old Apr 14, 2012 | 09:14 PM
cadman's Avatar
I managed to take one picture and make a diagram when I spliced the shift lock connector:
Much of the wire color codes for the earlier trucks are incorrect in the Toyota EWDs, so with a little ohmmeter work this is what it is on my truck.
Old Apr 15, 2012 | 11:41 AM
Cadman I wired it up just like you showed. The colors on my '95 matched up with your '89 too. I heard the relay clicking in the dash, but the shifter button would still not depress.
I got tired of messing with it, so I removed a couple screws on the shift lock actuator solenoid and removed it completely.
After removing it, you still have to depress the shifter button to get it into gear, which was really my only concern about removing or disabling the shift lock. This is satisfactory to me, so it's staying this way.
I'm going to cross post this into my build thread for another search reference.
Old Apr 15, 2012 | 04:40 PM
cadman's Avatar
Your shift lock ECU or the shift lock unit may be faulty, most likely the lock unit if either of the two.
okamikai
Apr 30, 2018 10:19 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
Tykiller1994
Aug 10, 2015 07:49 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
PlayAwhile
Jul 20, 2015 11:36 AM
