vent on passenger side
Old May 16, 2012 | 05:37 AM
jayglamis's Avatar
Can anyone explain what this vent is for? can it be removed? hits my new motor mounts. I can grind the mount to fit. it is on the passenger side, 3.4 out of a 03 tundra
Old May 16, 2012 | 09:20 AM
SacRunner's Avatar
That's a coolant drain spout that you can attach a hose to when draining the block (back out that brass plug to allow coolant to drain). Lots of guys have ground a notch into their motor mounts to clear that fitting.
For what it's worth, the block I'm using (from a '96 4Runner) doesn't have that fitting so I had no clearance issues; I just have that brass plug and a threaded hole where that fitting could have been installed.
I would imagine you could remove the fitting without issues unless, for whatever reason, you need to drain the coolant from the block after it's been dropped into your truck and don't want coolant running out everywhere.
Old May 16, 2012 | 08:17 PM
vasinvictor's Avatar
Holy motor mount, that is nice craftsmanship. Your work? Yeah, just notch it out like everyone else has done.
Old May 16, 2012 | 09:33 PM
jayglamis's Avatar
No not my work got them from Chilkat design. i just modified them to become a semi solid motor mount
Old May 18, 2012 | 08:03 PM
spinyard's Avatar
yeah nice tig welded mount must have removed a 4cyl 22re to have to make mounts like that.... that some race car work there! btw i just ground a spot for that to clear!
Old May 20, 2012 | 06:59 PM
jayglamis's Avatar
yea thats what im gonna do. the mount is for my desert truck
Sep 4, 2015 09:27 AM
itzmywife's
Jul 25, 2015 04:55 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
yourrealdad
Jul 21, 2015 11:13 AM
crashburnoveride
Jul 10, 2015 06:39 AM
