stiffener plates
Old Jan 19, 2012 | 04:05 PM
son_of_a_lc's Avatar
stiffener plates
I am swapping a 3.4 from an auto 4runner into a manual tranns 3.0 4runner.
Since the motor is an auto it doesn't have the stiffener plates that bolt to the block and the bottom of the 5speed bell housing.
I tryed to bolt the 3.0 brackets to the 5vz block but they seem to be different, off by maybe a 1/8 inch from the hole alignment.
My question is should they work? How necessary are they considering they never came with the autos, and if i do need need 5vz plates, how do i get them?
Old Jan 19, 2012 | 04:21 PM
dntsdad's Avatar
I dont have them on mine. Mostly seems stiff
Old Jan 24, 2012 | 04:38 PM
Trebor's Avatar
Mine bolt right up.
Old Jan 24, 2012 | 05:02 PM
Houston5's Avatar
Does anyone have pics of the plates? Because I swapped an auto motor to a manual 4 runner as well
and I didn't put the plate on the bottom of the trans bellhousing. I wanted to know if this is the plate everyone is talking about. Does it even matter?
Old Jan 24, 2012 | 05:48 PM
dntsdad's Avatar
I cant find a picture but to call them plates are probably not accurate. they are basically brackets that attach to the bellhousing and then bolt to the block along the oil pan bolts, but not using the oil pan bolts. Much larger.
Sounds like you might be referring to the inspection plate? Thin piece that is sort of a half moon that goes up into the flywheel area from underneath?? I did install this.
Old Jan 25, 2012 | 03:37 AM
Houston5's Avatar
That is the one I was thinking of. I must have lost the one from the 3.0 cause the one I have doesn't line up with the bellhousing bolt holes.
Old Jan 25, 2012 | 06:41 AM
bend's Avatar
I didnt have an inspection plate either. I think there are some brackets that may cover up the clutch. I have two stiffner brackets and one mystery bracket. Looks like it covers up the flywheel.
Old Jan 25, 2012 | 10:52 AM
Originally Posted by Trebor
Mine bolt right up.
so your 3.0 stiffener brackets worked on the 3.4 block?
Old Jan 28, 2012 | 01:18 AM
stihl460's Avatar
Did bolt up on my 96 block. It took some time to get both sides to align though.
Old Jan 28, 2012 | 07:41 PM
superchiem's Avatar
My stiffiner arms bolted up for auto to auto. If you reused the 3vz bell housing then they should match up to block and bell housing.
kawazx636
Oct 6, 2021 03:03 PM
kawazx636
Sep 29, 2015 08:22 AM
bhaithc
Sep 17, 2015 07:53 PM
AlexJet
Sep 14, 2015 09:00 AM
