ADD wiring
Old Sep 9, 2012 | 05:37 PM
slacker's Avatar
ADD wiring
I have read and searched , and noticed there is no info. for ADD wiring ?
Old Sep 9, 2012 | 06:25 PM
waskillywabbit's Avatar
Lots of 3.4 swap variables. Wanna narrow that down a tad.
:wabbit2:
Old Sep 9, 2012 | 07:20 PM
vasinvictor's Avatar
I have been putting this off too. Last good idea I had was a 2 position toggle switch to activate the appropriate VSV for ADD on, and ADD off. Right now I'm opening the hood and hooking up one vacuum hose for "disengaged" and hooking up the "engaged" one when I hit the trail.
Old Sep 10, 2012 | 05:20 PM
slacker's Avatar
exactly , but to get around that hastle, We have always done the IFS manual hub swap , and bypassed the vacuum assy , seemd like a no brainer ! and much better set up IMO . but some fellas have wired the vac switches to work with the stick and light . I have been reading but cant find any real refferance to how this is accomplished
Old Sep 10, 2012 | 09:18 PM
SacRunner's Avatar
My swap isn't running yet (long, long story) but I "figured out" the ADD wiring a while back (at least in theory) for my swap, '91 3.0 M/T with ADD and a 96/97 3.4 M/T with ADD (no 2-4 select switch).
The absolute best advice I would give is to go through the EWD for your applications and eliminate all un-needed circuits (yes, redraw the schematic on paper).
For instance, redraw the 3.0 circuit but only include wires labeled 3VZ-E omit all the 22-RE lines, you'll notice it becomes a really simple circuit:
Then do the same thing for the 3.4 circuit:
Then its just a matter of what wires need to be spliced together and where:
(Sorry about the rotated photo, I'm having issues and whatever I do won't rotate it the correct way).
Again, this is what I did for my specific swap, and I'm not even sure if its correct yet.
Old Jan 19, 2016 | 07:15 PM
Tiletony's Avatar
Did it work????
Old Jan 19, 2016 | 10:42 PM
SacRunner's Avatar
Yes, that wiring works for my swap.
Old Jan 20, 2016 | 08:10 AM
screamer76's Avatar
Sacrunner's got the right idea.
Old Feb 6, 2016 | 05:56 AM
Tiletony's Avatar
Sac runner I had been messing around with this for a while. Last night I tested the switch in the trans case with 12 volts and it works, when engaged to 4x4 test light come on when 2x4 test light turns off. I have a 3.4 swap in a 94 3.0 truck while a solid axle with manual hubs. So I don't have the ADD wiring up front any more but I still have the VSV valves that one has powe to at all times and the other never has power. If possible can I run a new circuit from the trans to the gauge cluster in order to get the light working? If so any suggestions? It is the only that doesn't work on the truck drives me crazy.
80Truck
Oct 12, 2025 07:25 PM
edoyle12
11
Mar 20, 2017 02:26 AM
Ironmike4x4
Feb 3, 2016 11:13 AM
TDonkey
Jul 26, 2015 10:14 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
