Swap finished, brake issues.
Old Aug 20, 2011 | 11:46 AM
DSTRBD's Avatar
Ok so my swap is done, runs great blah blah blah, I also did a SAS and FJ rotor's at the same time. Everything seems fine except I get a slow pulsing as i'm coming to a stop...kind like the booster is pulsing..hard then soft and so on. The brakes stop the runner just fine, but it is defiantly not consistent pressure to the pedal. I am thinking something is hooked up wrong to the booster?
Where is your booster hooked up to vacuum? what check valve did you use? Pic's? thanks!
Old Aug 20, 2011 | 12:52 PM
vital22re's Avatar
totally a bro
are the brakes pulsing or is the motor pulsing? I would check your rear brakes and have the drums turned, clean the shoes, and adjust.
Old Aug 21, 2011 | 05:33 AM
DSTRBD's Avatar
Its not the motor, just the brakes. like they are getting boost then no boost off and on as you come to a stop.
Old Sep 30, 2011 | 03:52 PM
timmJ's Avatar
Did you figure this out?
I have been driving with my swap for about three months and this is one of three issues I am living with.. If you did figure this one out can you post up what you did to correct?
Old Sep 30, 2011 | 04:02 PM
nv4runner's Avatar
Did you use new rotors or used ones? If used, did you turn them before the install?
Old Sep 30, 2011 | 06:28 PM
j2the-e's Avatar
Even if you un-hooked the booster while stopping, it should have enough vacuum to stop without pulsing. Does the steering wheel shake when stopping? Do you feel it in your floor or seat? Is it ONLY in the brake pedal?
Old Sep 30, 2011 | 10:32 PM
A New High's Avatar
The check valve just holds vacuum in the booster so when you shut the engine off, your pedal stays consistent.
Try removing your check valve to eliminate that possibility.
You could even unplug your booster all together- while using extreme caution, knowing your brakes are gonna suck holes- to see if that eliminates your issue or not...
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
chukarhunt
Dec 8, 2019 11:39 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
