3.4 maf conversion
Old Apr 20, 2012 | 06:41 AM
chrisdish's Avatar
3.4 maf conversion
i searched my arse off on this and couldnt find anything so if anyone finds it easy please forgive me. i just finished me 3.4 swap into a '91 sr5 and i'm using a motor out of a '96 4runner. the maf i bought used off ebay is dead(no resistance) and i wanna use a new style maf for better airflow. i know i need to repin the harness at the maf connector but is there any other mods that needs to be done to support this? anyone have a link to a write up? thanks in advance for any help.
Old Apr 20, 2012 | 02:14 PM
vital22re's Avatar
totally a bro
search. There is a write up on here for the conversion. You will need either the matching airbox for that year style sensor as it holds the sensor. Or pick up a cheap aftermarket intake for the later year 3.4 with the drop in filter rather than the inline filter.
Old Apr 21, 2012 | 08:47 AM
chrisdish's Avatar
not trying to be an ass but if you read my post i tried searching. i've tried different combinations of words, google, this forum...i cant find ˟˟˟˟! trust me, i try to do a lot of legwork before i make a post.
is the maf bolted into the airbox or is it in a tube like the 96-2002 4runners? thanks for the info you gave me though.
Old Apr 21, 2012 | 09:06 AM
chrisdish's Avatar
i just looked through the appropriate forums and couldnt find any write-ups. no stickys....nothing. perhaps since it's so easy to find you could point me in the right direction. again not trying to be a dick but if you're so quick to say search it must be in an obvious spot that i'm missing.
Old Apr 21, 2012 | 09:09 AM
vital22re's Avatar
totally a bro
I googled Maf swap and found this.
http://www.ultimateyota.com/index.ph...6&topic=3915.0
There is difference in the 98 or 99 and up as they are a drop in style that screws into the molded tube that sticks out from the air box.
The older style is massive and is bolted to the airbox and has the intake tube attached to it so its "inline" with the intake.
Old Apr 21, 2012 | 09:11 AM
bobbybouche's Avatar
https://www.yotatech.com/forums/f116...-specs-212879/
Old Apr 21, 2012 | 09:22 AM
vital22re's Avatar
totally a bro
does not appy here.
Old Apr 21, 2012 | 09:29 AM
Originally Posted by vital22re
does not appy here.
Right you are
Old Apr 21, 2012 | 12:53 PM
chrisdish's Avatar
thanks for the help bobby but i'm sporting a 3.4 now. ahh....thank you so much mr. vital. google can be a bitch when it comes to searching. you try to use key words and it still cant give you what you want. once again....thank you for pointing me in the right direction.
Old Apr 21, 2012 | 04:13 PM
slacker's Avatar
I had to re pin mine in my trekker .. after MONTHS of hair pulling because of a "check engine code" .. I had a re-pin diagram for all the years , but cant seem to find it
Old Apr 21, 2012 | 08:52 PM
aferg's Avatar
Try this:
http://bb.bc4x4.com/showthread.php?1...r-build/page23
Post #343 down...
Slacker, there is a lot of information in that build!!! :-)
jb451
7
Oct 7, 2022 06:58 AM
ClintonP929
3.4 Swaps
64
Jun 13, 2017 01:46 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
runnermedic
13
Sep 21, 2015 05:20 PM
dlaiben
3.4 Swaps
Sep 3, 2015 09:57 AM
