A different kind of crossover question...
Old Oct 27, 2011 | 08:55 AM
Replicant's Avatar
I attempted to search, but this is a bit different question than the many that are on here... Basically, when I got my motor from the junkyard, they had already removed it from the vehicle, and they were lazy, so instead of taking the downpipe flange (where the crossover comes down) they cut it off. I didnt have one. So I re-used the stock 3.4 piping and made my own crossover, but without having the flange, I just plumbed the passenger side straight into the driver side, much like the ORS crossover. The problem is, the stock pipe is like 2 inches (I believe the ORS is 2.5)....will this be too much restriction where these TWO 2in pipes go into ONE 2 inch pipe? Still seems better than the stock 3.0 design, but I dont want any heat backup or anything that could damage anything.
Old Oct 27, 2011 | 03:28 PM
dntsdad's Avatar
I would just buy a "new" crossover and do it right.
Here is one cheap as hell!!
https://www.yotatech.com/forums/f109...-parts-240907/
Old Oct 28, 2011 | 05:51 AM
tacovr6's Avatar
I second that, do it right, or you will run into problems in the future
Old Oct 28, 2011 | 06:02 AM
Replicant's Avatar
Yea, going to have to anyways...did a test fit and found out I am not clearing the aluminum heater hose anyways...guess the first one was a learning experience!!
Old Oct 28, 2011 | 11:28 AM
calipatient's Avatar
Dont sweat it, You will probably have a few learning experciences with this swap... I know I did!
Old Nov 1, 2011 | 09:58 AM
Replicant's Avatar
Well, I got the crossover done, engine is in, mounted, tranny, fuel lines, heater hoses, A/C, P/S, all that. So I am pretty much on to wiring....heres the hard part. I am no good at wiring and dont even know where to start. I believe I am going to need to get the 3.4 ECU plug that normally comes from the body harness of the 3.4 to the ECU right?
Old Nov 1, 2011 | 12:09 PM
Replicant's Avatar
Anybody in AZ wanna trade a 30 pack for some help? Ha
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
zytra
Jan 24, 2019 03:16 PM
live4soccer7
May 11, 2016 06:52 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
