3.0 to 3.4?
Old Jan 3, 2012 | 03:26 PM
jake90's Avatar
3.0 to 3.4?
Hey guys,
I have a 90 SR5 pickup with a newly rebuilt 3.0 that made a horrible whacking sound. We pulled the oil pan and it turns out the crank broke. The dilemma is is it worth dopping 250 bucks into it to put a new crank and bearings in it or put in the complete running 3.4 out of a T-100 that i already have?
I need to get it running soon for school and I dont have too much income right now. So what would you guys do?
Broken crank
And my rig. Looks awfully tall without an engine.
Old Jan 3, 2012 | 03:50 PM
smithoman's Avatar
I know that you must use the computer from the T100/3.4. Will that work in your 90?
Old Jan 3, 2012 | 04:31 PM
jake90's Avatar
Yeah i have the ecm from the T-100 and its an auto trans. But I'm gonna use a manual trans and I'm not sure if that would be a problem?
Old Jan 3, 2012 | 07:09 PM
vasinvictor's Avatar
You can repin your auto harness to work with your manual. "dntsdad" has a detailed writeup here about halfway down the page. Since you have the complete doner I would stronly consider the swap. It would make it a low cost and quick swap. but I wouldn't tear up a good T100 just for the swap, unless it's already junked up.
edit: I see you've already cut your body plug, so it looks like you've got your mind made up
Old Jan 3, 2012 | 07:23 PM
MudHippy's Avatar
Originally Posted by jake90
Broken crank
Wow! That's a first!!! NEVER heard of a 3VZ-E snapping a crankshaft before.
What I'd do is fix it. But that's just how I roll...because I <3 my 3VZ-E...and I don't have a spare 5VZ-FE layin' around.
BTW, who did that rebuild? If you don't mind me askin'...
Old Jan 3, 2012 | 10:15 PM
jake90's Avatar
Yeah i was gonna attempt it but i backed away at first, wiring has me nervous I don't want to fry anything. I'm confused on the auto tranny harness off the motor if I'm doing a 5 speed do i just cut it off?
Old Jan 4, 2012 | 05:18 AM
You can repin your auto harness to work with it if the plugs match up. Any reason you don't want to swap in the T100 auto tranny? It'd take the hassle out of getting a new ECU and repinning the harness.
Old Jan 4, 2012 | 02:55 PM
jake90's Avatar
The T100 tranny is a column shift unlike the Tacomas an 4runners. I got the tranny too but I'm not sure if you can convert them to floor shift?
Old Jan 5, 2012 | 04:43 AM
Trebor's Avatar
You need to keep reading on here. It has all your answers. The auto 3.4 comp will work with your 5 speed. Fix the 3.0 later to sell.
Old Jan 5, 2012 | 06:15 PM
4x4runr's Avatar
To answer your question, with school coming up ect...
If $250 is all there is to fixing the 3.0, I would go with that. Swapping to the 3.4 can be very costly and time consuming.
I mean, if your window shatters, do you honestly say, should I spend $70 on a new window or should I just get a new door with a window in it?
LOL anyway, that's how I read your question. Good luck with the swap!!
Old Jan 6, 2012 | 07:11 PM
wakkjobb's Avatar
Being pressed for time, fix the 3.0 and keep reading about 3.4 swaps until it breaks again or whenever time/money allow for it. Read everything you can about wiring; it is rather vital to the swap. I don't think it was mentioned, but isn't the T100 t-case driver's-side drop and the truck/4Runner passenger-side drop? If so, that's another thing to swap or buy an adaptor for; and those run about $3-400... I need one to run geared cases behind the R150 going into my 84 POS. One step at a time...
So yeah, my vote is to fix the freshly rebuilt engine; maybe go raise hell at wherever rebuilt it. Seriously, a broke crank? WTF? I can see a spun bearing, maybe a bent rod... but a crank? C'mon...
Old Jan 7, 2012 | 04:04 PM
jake90's Avatar
I took the crank into the local toyota dealership an they want over a grand for one but it looks like they might replace it from a defect in the metal so that'll be nice.
Old Jan 8, 2012 | 06:11 AM
wakkjobb's Avatar
So everyone's dying to know... who rebuilt the engine? I bet we're hoping you can raise hell about the crank and get a second rebuild for free; or heavily discounted.
A quick check at rockauto.com shows re-man'd cranks go for about $300 give or take... it's no surprise OEM stuff is oodles of money, but $1000? Was that just the crank or with installation? I could see a grand for and to install, but a grand for a stock crank... nah. Hell, a forged Eagle crank from Summit is about $550! Forged 4340 steel, not cast stock stuff.
Old Jan 8, 2012 | 05:02 PM
jake90's Avatar
I don't know who rebuilt the engine nor do I have any paperwork on it because I had the intentions on just pulling the 3.0 out and swapping in a 3.4.
But I tell ya the Toyota mechanics were pretty shocked when I brought the crank in in two pieces. I was told it was 1050 for just the crank. But those guys are gonna try their best to get me a new one under warranty.
Old Jan 11, 2012 | 07:38 PM
wakkjobb's Avatar
Any word yet?
Old Jan 13, 2012 | 07:19 AM
jake90's Avatar
Any word yet?
No not yet. Kinda dissapointed with Toyota... A guy at the local dealership has been calling people but he can't get ahold of anyone of importance. I think I'm going to just order a crank so I can this thing rollin.
Old Jan 13, 2012 | 07:53 PM
jake90's Avatar
3.4 swap has begun! No more screwin with the 3.slow. Almost got the wiring figured out, now I just need to find a fuel line and make the crossover exhaust and I'll be ready to drop it in.
Old Jan 19, 2012 | 09:09 PM
jake90's Avatar
Well I built my crossover exhaust today out of the factory exhaust manifold using one of the threads on here about how to do it. I also replaced all the belts and am now waiting on a fuel line to come in.
But man does the wiring suck, I think I get it all figured out and squared away and then I get unsure and don't move ahead any further....
Old Jan 20, 2012 | 08:20 AM
You can reuse you stock 3.0 fuel line.
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
sphealy
Sep 3, 2015 07:55 PM
ashersullivan88yota
Aug 19, 2015 06:00 PM
Valvoman
Aug 8, 2015 03:52 PM
93toyoguy
Aug 2, 2015 07:41 PM
