PDA
View Full Version : 3.4 Swaps
Pages : 1 2 [3] 4 5 6 7 8
  1. Tac mod for 1st gen V6
  2. Alternator charging/wiring HELP PLEASE!
  3. 3.4 swap tranny question
  4. 1988 runner diagrams
  5. 22re swap AC compressor question
  6. One central file location for EWD, FSM, etc.
  7. No power brakes/High idle !!!!
  8. Good swap candidate?
  9. 1996 Engine Only with 1995.5 everything else
  10. what muffler/exhaust are you using?
  11. Wont turn over!!!
  12. Toyota 3.4 swap, high idle and running rich. Help!
  13. Is the EVAP Box necessary?
  14. Passenger Side Motor Mount fits with grinding but what is that fitting?
  15. Help me please!
  16. Plug definition?
  17. Swap or not? Madman's long strange trip.....
  18. 3.4 swap problems?
  19. 3.4 swap won't rev above 2500-3k
  20. 94 3.0 4wd auto to 98 3.4 2wd auto
  21. 3.4 swapped Cross "under" questions and upstream o2 sensor results?
  22. EVAP/Battery harness plug help/ MISC ?'s
  23. what 3.4 ecu do i have? and witch one will work on my s/c engine
  24. R150 trans rattle
  25. Which catalytic converter ?
  26. bell housing interchange between 3.0L R150 & 3.4L R150?
  27. 3.4 wirinig
  28. relay for fuel pump
  29. Where is the A/C amplifier
  30. URD 7th and fuel line connection with swap
  31. What am I doing wrong in TIS
  32. My first, and hopefully last engine swap.
  33. Best Clamp on style air filter
  34. 3.4 swap pinouts? TIS help
  35. script to download fsm's from toyota -- anyone want a copy?
  36. 3.0 block heater in 3.4??
  37. Good places for a 3.4 swap in Washington.
  38. 3.4 swap question
  39. 2002 2.7L swap to 2002 3.4L
  40. 3.4 swap
  41. catalyst monitor wont run
  42. Crossover pipe newer style -- advice?
  43. 88 xtra cab 96 3.4 swap
  44. 2000 auto into 93 auto
  45. Which vapor pressure sensor part #??
  46. MT ECU Connectors -- no longer available from Toyota
  47. 96 4runner 3.4 A/T to M/T
  48. Removing 3.0 Wiring Harness
  49. 3.4 swap keeps bursting fuel return line hose.
  50. Recommendations for Mechanic or Help in Engine Swap - Southern Indiana
  51. issue's with Alternator fitting after swap
  52. 1988 4Runner 22re 3.4 swap
  53. Radiator recommendations
  54. HELP! po130 and po133 stft -20.31 ltft+19.53 new denso o2
  55. Rookie 3.4 questions
  56. 3.4 swap, how much can I get away with?
  57. 94 3.0 pickup 5 speed to 3.4 99 auto vehicle speed sensor??
  58. 97 3.4 into my sons 94 3.0
  59. data link connector ?
  60. 3.4 swap with 1997 transmission
  61. And so it begins -- 95 3.0 -> 98 3.4
  62. Are these prices outrageous or what?
  63. 90 4runner 3.4 swap injectors not firing
  64. How many miles is too many miles, 220?
  65. Looking for a shop in norcal
  66. 3.4 Swap on 2nd Gen runner! Can someone help
  67. Relocating rear axle 2" to accommodate an 99 r151f in my 95 5vz 4runner
  68. 98 Tacoma e5 plug ?
  69. 3.4 swapped 90 4runner falling on its face
  70. irab88 adds another liter: 22R-EC to 5VZ-FE
  71. cruise control question
  72. Adding a York compressor post swap.
  73. 3.4l 99 4runner auto to 94 3.0 pickup 5 speed wiring questions?
  74. 3.4 swap vss question
  75. 98 Tacoma Engine Swap, Suggestions?
  76. 97 4Runner auto ECU/motor/harness into 91 4Runner 5 speed
  77. 3.4l swap into 85 4runner
  78. wiring harness routing left side 2000taco 3.4 to 92 truck
  79. Vapor Pressure sensor/MAF sensor Relation
  80. Running drive cycles for monitors on jack stands?
  81. 3.4 swap into 1988 4runner hesitating/loss of power
  82. Grounded o2 Sensor Wires
  83. p0141 code... wrong rear sensor?
  84. 90 pu with a 3.4 and a trd supercharger (not quite running right)
  85. Any shop recomendations
  86. 88 Pickup v6 Manual 4x4 - 3.4 Swap
  87. Newbie needs help on fuel pump problem
  88. just started 3.4 swap and have a few questions
  89. Super weird, bad instance.
  90. How many of you are still DD your 3.4 conversion?
  91. 1989 4runner 3.4 swap
  92. 3.4 swap questions
  93. 2nd Gen 3.4 Leak
  94. 3.4l swap fuel problem
  95. Mix and match 3.4 swap parts?
  96. 22RE to 5vz, custom harness or dash swap from donor?
  97. Stupid MAF and trans pan ???
  98. 3.0 auto to 3.4 swap questions
  99. Newbie 3.0 to 3.4 Conversion PLEASE HELP
  100. questions about the 5vz-fe(3.4l)
  101. Few issues after swap complete
  102. Revilo's 3.4 swap
  103. Mileage after a swap?
  104. 1988 Motor Mounts?
  105. Super squish and hard clutch
  106. heater hoses
  107. Good source for a motor?
  108. What to do about the Fuel Return Line?
  109. Codes p0758 & p1700
  110. 3.4 swap bogging sputtering miss fire issues
  111. one more harness that i cant find info on . 3vze engine to body harness. help please.
  112. 1988 4runner 3vze engine to body harness wiring info need help.
  113. 1989 4runner engine to body harness
  114. wire harness ?
  115. T100 auto with 97 4runner auto shifter problem
  116. PO 441 "Evap Emissions Control" flow code. Anyone else running without the EVAP syste
  117. No Power AT ALL
  118. 3.4 oil dipstick
  119. yet another wiring ?
  120. lower belt housing shield
  121. E12 plug missing not cut from 3.4 4x4 harness ??
  122. 3.4 Wiring Problems
  123. completely lost
  124. Oregon's Lone Wolf 3.4 swap
  125. Oil Sensor Gauge
  126. Throttle Body
  127. many speed sensor pins
  128. Terminal Number ID's
  129. No E5 Plug
  130. 94 MT Runner 3.0 MT to 3.4 Auto with 97 MT ECU
  131. Toyonlyswaps contact info
  132. 3.4 Swap Temp.. HELP!
  133. ECU year VS 5vze year & CA Smog.
  134. Time to pull the trigger on my swap
  135. Finale
  136. TIS Problem
  137. Tach Mod Questions
  138. Sarting a 3.4 swap with my son
  139. Wiring and Me!!
  140. cant find info on Tach Mod (I searched)
  141. Stuck on E12 Pin 26 and II3 #9
  142. 3.0 to maybe a 4.3 chevy??? or 3.4.
  143. Whats your manual swap with auto ecu idle at?
  144. 95 runner 3.4 auto, to r150f with auto ecu problems
  145. 3.0 Body Harness To 3.4 ECM
  146. Is It worth posting my pin outs for my swap
  147. 3.4 O2 Sensors Front or Rear? (Pics)
  148. 3.4 into a 84 4runner problems
  149. loss of power in gear
  150. 3.4 Swap Mechanic Needed In Dallas TX
  151. sc'd 3.4 swap running lean at constant speed
  152. 3.4 Swap Clutch Fork and TO Bearing Info
  153. 95 4Runner AT ECU Verification
  154. Clutch issues?
  155. Down to P0505 last code!!
  156. 3.4 Radiator vs 3.0 Radiator
  157. pics of your 3.4 wiring swap
  158. 3.4 Swap connector part number issues
  159. Toyota Red Coolant OK with Copper/Brass Radiator and Heater Core?
  160. 5vz-fe swap and build
  161. 3.4 Swap Alternator Belt Options
  162. no power brakes at high rpms
  163. Any experience with Cliff in Denver?
  164. Clutch slipping after swap difference in length of output shaft to blame??
  165. Using a 2wd 3.4 harness
  166. 1989 4runner 3.4L swap
  167. Need TPS help!
  168. Power steering help!
  169. Byrdman's 3.4 Swap
  170. 1993 4Runner EWD's
  171. 22RE to 3.4 A/C Hose Info
  172. Please help clutch priblem
  173. A/C comp. mounting issues
  174. Arizona smog
  175. Gonna need some brakes..
  176. 91 4runner 3.4 swap no fuel??
  177. long term fuel trim around -18%
  178. Wiring questions
  179. 1989 wiring question
  180. 1993 swap help!
  181. starting issue - need help
  182. having trouble with wiring
  183. 93 Pickup 3.0 to 2000 4Runner 3.4
  184. 1991 Toyota Pickup getting a 3.4 from a 1997 4Runner
  185. high idle when warm
  186. Random backwards compadable wiring question
  187. Plugs
  188. 88 3vz to 5vz
  189. My first 3vz-e to 5vzfe conversion in my sas'd 4runner(any pointers appreciated)
  190. 3.4 cold start problem
  191. Hood scoops/Custom hoods 84-88 WITH Supercharger?
  192. MAF sensor
  193. 88 22RE Connector Identification
  194. Homemade tool to drill block for dipstick
  195. 3.4 in my 88, no body lift, hood closes
  196. Power Steering Hose for 22RE - 3.4 in 88 P/U
  197. new member need help
  198. R151F Shifter Mod after 3.4 Swap?
  199. Mussy01's 3.4 swap final questions - HELP :)
  200. Toyonlyswaps or ORS wiring harness?
  201. Body Lift
  202. Evap system using toyonlyswaps harness
  203. Chopped 4Runner Swap
  204. 93 pickup 4x4 - 3.4 swap
  205. need a 3.4 alternator
  206. Gibson Headers with ORS crossover?
  207. 88 4runner 3.4l swap
  208. JasonYota's 3.4 swap started
  209. oil filter oil cooler swap
  210. Heater Hose configuration ?'s
  211. 5VZ into 92 P/U
  212. Starting issues
  213. 3.4 Swap CA Smog Info
  214. 94 4x4 with electronic speedo - HELP
  215. Auto Donor Ok for My App?
  216. I Could Get a 5VZFE w/Engine Harness Cheap
  217. Are the 5VZFE and 3VZE Crankshaft Interchangeable?
  218. Alt upgrade for Swap
  219. Blew out the FC pin. What are the options?
  220. 85 22re ----> 99 3.4
  221. Please help I need EWD for 1991 3.0 Pickup 4x4 manual
  222. 92 3.0 to 3.4 swap. help!!!!
  223. Gearing post-swap ?
  224. How much should I pay for an engine?
  225. My poor 4 Runner is fried !
  226. Need some slightly less common info
  227. high rpm problems
  228. B4Runner's 3.4 Swap
  229. California / Bay Area 5vz swap shops?
  230. 3.4 or 22RE Fuel Pump?
  231. not firing. possible issues?
  232. 95 runner 3.4 with no evap. bypass to the intake
  233. swap problems am2 fuse link
  234. Do 98 3.4 auto and 98 and 3.4 manual ecu's have the same plugs/pins?
  235. 3.4 swapped with a340h trans pulling up p1700 code
  236. Moving to CA- Smogging my 3.4 swapped 93... anybody else go through this?
  237. Can you use 93 Automatic with 97 ECU?
  238. ??3.4 swap from 95 t100 to 91 4runner wiring
  239. 1st Gen 4runner 3.4L engine swap
  240. bellhousing help!
  241. quick wiring help!
  242. 95 runner with 98 3.4 swap tach help
  243. 1994 toyota 3.0 to 3.4 or 4.0?
  244. After a trouble free year, I'm DOA
  245. 98 3.4 o2 sensor vs 95 3.0 o2 sensor are they the same?
  246. 3.4L 2WD into 3.0L 4WD?
  247. 95 runner 3.0 to 98 tacoma 3.4 help locating the obd port
  248. BR-3 Diagnostic Scanner
  249. 95 runner 3.4/auto to Manuel swap, do you really need Manuel ECU?
  250. 95 4Runner regearing opinions
