Super squish and hard clutch
Old Sep 24, 2013 | 06:46 PM
devharm's Avatar
Hey guys, finally got he rig running but when i go to shift it doesnt really work to well. clutch is super squishy and nearly impossible to put into gear. random grinding here and there when i jam it like its telling me i dont wanna go there. Clutch worked fine before the swap but is really being a pain upon completing. I havent been able to get it out of first gear even. Any help/ideas would be awesome
Cheers
Old Sep 24, 2013 | 06:54 PM
Kiroshu's Avatar
-Check hydraulic clutch fluid level.
-Check hydraulic clutch system for leaks.
-Possible damaged and or faulty clutch master cyldiner...?
-Possible damaged and or faulty clutch slave cyldiner...?
-Air in clutch hydraulic system...? *Perform system bleeding*
Old Sep 24, 2013 | 07:08 PM
devharm's Avatar
Is there a how to on the forum for a bleed? Is there ways to test the cylinders as well? The rig shifted awsome before the swap. She shifts when the rig is off as well so im almost positive its not the tranny
Old Sep 24, 2013 | 07:14 PM
devharm's Avatar
I'll add that the rig did get stuck into reverse and when we had to move it for my landlord to reroof the house we picked the back end up with a fork lift and drug it. When we did that it unjammed and was able to shift when the rig was off.
Old Sep 25, 2013 | 05:57 PM
devharm's Avatar
So i think that im going to replace the trans oil and slave cylinder and hopefully that helps it. I tried to bleed the clutch and when i released the pressure and then closed it off then told my buddy to release the clutch it wouldnt release, it stayed sunk to the floor. Any ideas why that might be?
Old Sep 25, 2013 | 06:00 PM
Kiroshu's Avatar
Sticky Hydraulic Clutch Master Cyldiner.
Internally failed seals.
-Replace or Re-build Hydraulic Clutch Master Cyldiner.
Old Sep 25, 2013 | 06:19 PM
devharm's Avatar
Thats the reason why the pedal stayed enganged after my buddy released his foot?
Old Sep 25, 2013 | 06:26 PM
Kiroshu's Avatar
More than likely.
Old Sep 25, 2013 | 06:31 PM
devharm's Avatar
More than likely.
Alright, I was just going to replace the Slave cylinder but if you think its the Master i will go ahead and do both of them.
ALSO i was curious what this part was called. It is super loose and wobley and wouldnt mind replacing it if it is possible!
Old Sep 25, 2013 | 06:37 PM
Kiroshu's Avatar
Old Sep 25, 2013 | 07:07 PM
devharm's Avatar
Whoooa, i totally cannot read that.
Old Sep 25, 2013 | 07:16 PM
Kiroshu's Avatar
Shifter "Bushing" is what your pointing at.
The shifter bushing ball "seat" is also something too look at and both of these items are usually replaced together.
Old Sep 25, 2013 | 07:30 PM
devharm's Avatar
Awesome thank you, And was curious. Im just supposed to use 90W gear oil for the tranny right?
Old Sep 25, 2013 | 07:31 PM
Kiroshu's Avatar
What's the year make and model matching the Transmission...?
Old Sep 25, 2013 | 07:49 PM
devharm's Avatar
1989 r150 tranny and a 1998 3.4
Old Sep 25, 2013 | 08:00 PM
Kiroshu's Avatar
Yea should be 75w90 Gear Oil.
Old Sep 25, 2013 | 08:36 PM
devharm's Avatar
thank you sir
Old Sep 26, 2013 | 02:13 PM
devharm's Avatar
So I bought a new master and slave cylinder. Which should I replace first?
Old Sep 26, 2013 | 05:22 PM
Kiroshu's Avatar
^-- Really it is up to you not really a specified order of replacement.
If you have both... I would replace both.
Old Sep 26, 2013 | 05:27 PM
devharm's Avatar
Okay so i replaced both and began to bleed the system. am getting a solid brake fluid coming out but my clutch petal STILL sticks to the floor. like what the heck. Both cylinders are brand new too..
