A/C comp. mounting issues
Old May 30, 2013 | 01:39 PM
glowz825's Avatar
Exclamation A/C comp. mounting issues
So, I am at a point in my swap that I am starting to put things back together. While I was installing the a/c compressor I noticed that the pulley (which I swapped from the donor so I could use my 3.0 compressor) does not line up with the adjacent pulley . I took it the a/c comp. back out and measured the length of both compressors and noticed that the 3.0 compressor is about a 1/2 in shorter than the 3.4 4-runner compressor. Did Toyota use a larger compressor for the 4-runner? The 3.4 compressor is still good, should I use it instead? I am reluctant to use it due to my current system being charged and in good working order prior to the swap.
Thoughts?
Old May 30, 2013 | 05:12 PM
glowz825's Avatar
Well, I bit the bullet and evacuated the r-134 from the 3.0 system and swapped the top plate. Just another expense of the 3.4 swap LOL!
Old May 31, 2013 | 07:02 AM
aferg's Avatar
Do you have to change anything else on your original system to use the 3.4L compressor? I have the 3.4L compressor and could either swap the top plat or the pulley, I'd rather go with the newer compressor, but am not sure if i have to do anything else to be able to use the newer cooling refrigerant. My truck is an 89 so i don't know if i am using r134 or r-12??
Old May 31, 2013 | 09:02 AM
glowz825's Avatar
Aferg, your 89 probably has the r-12. My truck had the r-134 swap done on it prior. I have no idea what is involved with the r-134 conversion.
MO transplant
Apr 23, 2023 11:58 AM
stock87yota
Jul 31, 2015 10:08 AM
jackiebrownia
Jul 20, 2015 09:02 AM
jon.r
Jul 11, 2015 03:34 PM
bryan34w
Jul 6, 2015 05:53 PM
