Terminal Number ID's
Old Aug 21, 2013 | 11:48 AM
devharm's Avatar
Hey y'all i was curious if anybody had the ID numbers to the terminal plugs. I cant seem to find the ID to the IK2 plug on my harness. Any help would be greatly appreciated!
Cheers
Dev
Old Aug 22, 2013 | 10:15 AM
SacRunner's Avatar
What "ID numbers" are you looking for?
Are you looking for the housing part number?
These all start 90980-xxxxx with the xxxxx molded/stamped into the housing itself.
Or if you're looking for a connector you don't have you'll have to cross reference the connector image from the EWD with the images and description in the Toyota "Wire Harness Repair Manual (RM1022E)" at your local Toyota Dealer or from TIS.
The only other "ID number" I canthink of is the connector reference designator (connector name) from the EWD, but you already know that...IK2.
Old Aug 22, 2013 | 10:35 AM
devharm's Avatar
Awesome, i actually noticed those stamped onto the housings. That helps a lot Sac, much appreciated!
Old Aug 22, 2013 | 10:43 AM
devharm's Avatar
Ended up finding the number, but of course its for the male end and the female end is not the same number. SMH
Old Aug 22, 2013 | 11:26 AM
devharm's Avatar
The ID i found on my harness was 90980-11611. im trying to find the connector id which this plugs into. the Female one i beleive?
Old Aug 22, 2013 | 01:20 PM
rworegon's Avatar
90980-11611 is listed in the Toyota as Female
90980-11610 is listed as the Male based on my reading of the Toyota Electrical Repair Manual
ZGjethro
Jun 7, 2017 11:04 PM
White Stripe
Oct 6, 2015 10:47 AM
dbollier123
Sep 29, 2015 05:23 PM
irv
Sep 29, 2015 01:04 PM
runnermedic
13
Sep 21, 2015 05:20 PM
