bellhousing help!
Old Dec 13, 2012 | 07:32 PM
Belize Off Road Team's Avatar
bellhousing help!
it seems that the bellhousing from the 97 V6 auto 4x4 has a different bellhousing to the auto on my 93 4x4 pickup. i was under the impression that bellhousings might be shaped differently but the bolt holes would match.
is there a reason or are they all different just require something to make them work?
example, the bottom bolts on the 97 auto bellhousing seem to bolt from front to back rather then back to front like the 93, so the threads wont work the way they should.
Need HELP ASAP! removing 3.4 tomorrow and need to know before i do this.
Old Dec 13, 2012 | 08:31 PM
bump my original less noob question.
Old Dec 13, 2012 | 09:45 PM
Bump!
Old Dec 14, 2012 | 01:01 AM
vital22re's Avatar
totally a bro
starter bolts up differently. On the manual transmissions the clutch slave in on the passenger side. That 3.4 transmission is designed with the idea that the exhuast will be routed on the passenger side. Your 3.0 trans will bolt up to the 3.4 just fine.
beebeeri000
Oct 2, 2015 10:42 PM
viesail
Sep 21, 2015 06:00 AM
mizombie
Aug 25, 2015 06:28 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
